Michelin Pilot Sport A/S Plus ZP - Anyone else have this problem?
Old 05-13-2012, 01:12 PM
  #41
Jet-Jock
Support Corvetteforum!
Jet-Jock's Avatar
Here's a few pictures of the Nitto NT555 that I have on the forum:
Front Side Wall
Old 05-13-2012, 02:50 PM
  #42
rustyguns
rustyguns's Avatar
i run a racing alignment so mine cord on the inside edge!
and i run 30 lbs all around on the street. but i still get about 16, 000 miles out of them.
I think your doing too many burnouts !
Old 05-13-2012, 02:51 PM
  #43
rustyguns
rustyguns's Avatar
Front Side Wall
NICE LOOKING VETTE! If it is a 6 speed let me know if you ever want to sell it
Old 05-13-2012, 03:14 PM
  #44
Jet-Jock
Jet-Jock's Avatar
Yep Z51 MN6 with '09 Z06 shifter.
...and a Pioneer NAV system!
Old 05-13-2012, 03:53 PM
  #45
Corvette_Ed
Corvette_Ed's Avatar
Received 2,843 Likes on 1,801 Posts
Front Side Wall
I like the way those look. I like the sidewall a lot more than the Bridgestone Potenza's that are on the front of mine.
Old 05-13-2012, 06:57 PM
  #46
Jet-Jock
Jet-Jock's Avatar
BTW here's a picture of my last set of Michelin A/S Plus ZPs on the rear. Off center rib worn prematurely.
Old 05-13-2012, 07:19 PM
  #47
jrprich
jrprich's Avatar
These tires, say from 0-12k are really superb in handling grip wet or dry, or cold. That's probably a function of the reason their width is nearly an inch less than summer UHP and MP tires.
From my experience they just don't wear well, and the Plus model didn't completely solve the issue. I decided to go back to the full width summer tire considering I live in FL.
I drive my 99 in all types of weather, except snow/ice, and I drive it every day. My rear PS AS Plus ZPs went 33,000 miles of all sorts of roads. The fronts still have 40% of their tread left and both were still giving great traction and handling in all sorts of weather. Maybe I am wrong, but I think 33k on the rears is OK for C5 rear tires.
But if I lived in a warm climate I would choose a different type of tire since I would not need an AS tread.
Old 05-13-2012, 07:37 PM
  #48
Ghostface
Ghostface's Avatar
St. Jude Donor '10
It's happened to me and I've always kept the pressure at 30 psi. I don't know why and it's happened on at least 2 sets.
Old 05-14-2012, 12:08 PM
  #49
jrprich
jrprich's Avatar
To the many who have had this happen on their Michelin Pilot Sport AS Plus tires it would be interesting to know the aprox. miles on the tires when the rear center rib got down to the wear bars or beyond.
Mine were around 30-33k
Old 05-19-2013, 07:13 AM
  #50
bigcypress
bigcypress's Avatar
it's a year later and i'd like to know what occured with tires that wore centers early . why did it happen and what did michelin do in way of replacement ? i was going to buy some later this month .
Old 05-19-2013, 10:25 AM
  #51
retired08
retired08's Avatar
Default 33#'s
I'm running 33lbs. in mine and the wear is excellent.
Old 06-10-2013, 07:40 PM
  #52
C5Nate
C5Nate's Avatar
Kansas City Area Coordinator
St. Jude Donor '08-'09-'10-'11,'13
Michelin is reopening my case as we speak. I found someone with a little pull with Michelin.
He said its a known issue.
Old 06-10-2013, 09:30 PM
  #53
thmehr
thmehr's Avatar
On Michelin's website, the recommend tire pressure is 30 psi. That is what I run my at and is what is recommend by GM too.
Sorry to here that you have possible ruined your expensive tires.
Old 06-11-2013, 12:02 AM
  #54
torchredmadness
torchredmadness's Avatar
The wife's '03 coupe has 16,000 miles on her Kumhos and they look great.
Old 06-11-2013, 12:31 AM
  #55
Phanni
Phanni's Avatar
Received 1,731 Likes on 847 Posts
Do you really run 58 PSI?
Look at the pressures recommended on the driver's door.
The sticker says you should run 30 PSI, both front and rear (cold temp)
At 58PSI it's no wonder they wear out the center, you've overinflated by roughly 2X..
Old 06-11-2013, 02:14 PM
  #56
jrprich
jrprich's Avatar
I hope you didn't tell them you were using 58psi
Old 06-11-2013, 06:14 PM
  #57
2003 electronblue
2003 electronblue's Avatar
Try a 4 wheel alinement
To Michelin Pilot Sport A/S Plus ZP - Anyone else have this problem?
Old 06-12-2013, 10:54 AM
  #58
JetMechZ16
JetMechZ16's Avatar
Check a little further down on that response, he was joking he runs 28- 30 psi
Old 06-12-2013, 01:10 PM
  #59
VETJAZZ
VETJAZZ's Avatar
Just checked mine. They've been on the car a year with a little over 12,000 miles. No uneven wear - they still look new.
Old 06-13-2013, 11:16 PM
  #60
C5Nate
C5Nate's Avatar
Excuse me? WTF? "I" ruined them?
Read the post:
http://forums.corvetteforum.com/1580751411-post6.html
Quick Reply: Michelin Pilot Sport A/S Plus ZP - Anyone else have this problem?
