My engine has arrived - RHS 450cid & AllPro Heads
Old 12-19-2012, 10:10 PM
JaxEagle
JaxEagle's Avatar
Originally Posted by James2002z06
I you telling us that NA engine has 520 RWHP
On a 440, why not?
Old 12-19-2012, 10:13 PM
sfc rick
sfc rick's Avatar
Way too pretty to mess it up with gas and oil.
Old 12-19-2012, 10:43 PM
olbear1962
olbear1962's Avatar
Originally Posted by TheVettePirate
Engine ****
Old 12-19-2012, 11:06 PM
robert miller
robert miller's Avatar
Received 1,762 Likes on 1,529 Posts
Default ttt
To the OP here very nice build for sure love the RHS block. I cant wait until I get the RHS little 427 into the car and see what it does in the rollers.. Also that can on those numbers that is going to be one hel1 of a cam for sure.Robert
Old 12-19-2012, 11:32 PM
Vetteriffic
Vetteriffic's Avatar
That is so sweet...what vette owner doesn't want that? I KNOW I DO!!!!!
Old 12-20-2012, 12:02 AM
Millenium Z06
Moderator
Millenium Z06's Avatar
Man, thats a very nice looking build. Ill be giving them a call when I'm ready.
Old 12-20-2012, 10:51 AM
thecapo
thecapo's Avatar
Originally Posted by LoneStarFRC
Nice!
Who's offset differential mounts are you using? They look like OEM C6 pieces. Have they been modified to make the studs offset?
It is a stock C6 cradle only some slight modifications. RPM did the install at thier shop in Indy. Rodney and Jeremy are great guys to work to with and can answer any questions you may have.
Old 12-20-2012, 12:04 PM
LoneStarFRC
LoneStarFRC's Avatar
Location: Dear Karma, I have a list of people you missed.
Old 12-20-2012, 04:01 PM
Humy
Humy's Avatar
uh
Old 12-20-2012, 04:16 PM
Toque
Toque's Avatar
Location: Wylie TX --> Less is More, except under the hood !
Very impressive ! In for the results !
Are you telling us that NA engine has 520 RWHP
My little N/A 346ci puts 471/441 to the rear tires (medium size cam). I can easily see where a N/A 440ci would put 520 to the rear tires.
Toque
Old 12-20-2012, 05:44 PM
AU N EGL
AU N EGL's Avatar
Old 12-20-2012, 07:19 PM
thecapo
thecapo's Avatar
Originally Posted by 7LitreC5
That looks great! My 427 is coming out in mid Jan and is being sent to Golen for a rebuild and some enhancements. I am glad to hear that you had a positive experience. Mine will be run in on their dyno before it is shipped back.
Chad is great guy to work with and extremely knowledgable with over 20 years in the business. I called several shops before deciding to go with Golens. He is very meticulous, documents all the details, takes the time to talk with you, and goes the extra mile. Definitely one of benefits of dealing directly with the owner - you will not be disappointed.
Old 12-20-2012, 07:57 PM
  #33
Zr-1Mike00
Support Corvetteforum!
Zr-1Mike00's Avatar
Originally Posted by dankhts
Engine ****!
Looks like an awesome build!
Looks Amazing!!
Old 12-20-2012, 08:39 PM
  #34
angman5
angman5's Avatar
Old 12-20-2012, 08:46 PM
  #35
WKMCD
WKMCD's Avatar
Toque
Or a super mild 427 that puts down 577/530RW and makes 420ft/lbs of RWT at 2k RPM.
Old 12-20-2012, 10:39 PM
  #36
thecapo
thecapo's Avatar
Toque
Chassis dyno tuning scheduled in early January with the legendary Brian Walls at www.WallsRodCustom.com - results will be posted January 5th or 6th -stay tuned.
Old 12-21-2012, 07:58 AM
  #37
Toque
Toque's Avatar
Now your just bragging...
Toque
To My engine has arrived - RHS 450cid & AllPro Heads
Old 12-21-2012, 08:21 AM
  #38
ChromeC5
ChromeC5's Avatar
Impressive! Woo!
Old 12-21-2012, 08:45 AM
  #39
7LitreC5
7LitreC5's Avatar
Thanks. I needed to hear that. My current build never was right. It has always burned more oil than it should so it is finally time to take care of that. I really want it to be right this time and it sounds like I have no worries going with Golen.
Old 12-21-2012, 08:51 AM
  #40
WKMCD
WKMCD's Avatar
Regardless of what some people will tell you. It is very possible to have a stroker not burn any oil...mine doesn't. It's Darton Sleeves LS2 block with a 4.125 bore and a 4 inch crank.
Quick Reply: My engine has arrived - RHS 450cid & AllPro Heads
