C5 w/c6 zo6 brakes.... What size and offset?
Old 05-31-2014, 02:44 PM
scott88
scott88's Avatar
Default C5 w/c6 zo6 brakes.... What size and offset?
Having trouble finding wheels that would fit on a c5 with c6 zo6 brakes. Any help?
Old 05-31-2014, 02:55 PM
'Shifter
Thoroughly chapped
Support Corvetteforum!
'Shifter's Avatar
Location: If you're not angry, you're not paying attention
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17
NCM Member '09
I'm running TSW Nurburgring's 19" x 9" front (though 18" would have fit), and 19" x 10.5", and there is plenty of clearance. I don't have the numbers on the offsets handy though.
Old 05-31-2014, 03:33 PM
Black 02
Black 02's Avatar
They should be +50 F and +65 R. The spoke design of the TSWs leave a lot of clearance.
Old 05-31-2014, 03:35 PM
meflyfrc
meflyfrc's Avatar
You also will have to run C6 z06 or grand sport wheels unless you purchase custom wheels that will clear big brakes. C6z wheels on a C5 will stick out unless you have flared quarter panels.
I am running c6z brakes with grand sport wheels. I have flared rear quarters. The fronts stick out about 1/2 inch.
Old 05-31-2014, 09:23 PM
scott88
scott88's Avatar
Default ttt
Wow that looks great. So can you use any c6 standard offset rim with these rear fenders or just with the grand sport wheels?
Old 06-01-2014, 12:18 AM
zdeckich
zdeckich's Avatar
2017 Corvette of Year Finalist
2016 C5 of the Year
I believe my 18/19 forgestar f14 will fit c6z brakes.
Old 06-01-2014, 08:10 AM
ezrider4u2
ezrider4u2's Avatar
Hello,
I'm running a C6 Z06 brake kits with a 19/20 360 Forged Mesh 8 285 upfront / 345 in the rear with a 2 in tub kit. No flare but I can fit just about all of the tire in the well. My rear wheels are 20"x12.5" ET72 Before that, the car came with an 18/29 HRE 540 295/345 with regular C5 offsets but custom made for this application and it cleared the brakes.
Best bet is to work with a reputable vendor. Let them know exactly the type of mixed application (C5 w C6part) you have going and they will help you figure what will fit. The key will be getting the right off set and back spacing right.
Before:
After:
Old 06-01-2014, 10:59 AM
meflyfrc
meflyfrc's Avatar
With the flared rear quarter you will have to run a spacer to have a c6z or grand sport wheel sit flush. I am running a 20mm hub centric spacer with longer ARP studs. c6z and c6 grand sport wheels have the same offsets.
Old 06-01-2014, 06:43 PM
968ls1
968ls1's Avatar
Default GS Wheels on C5
Where did you purchase your hub centric spacers and what length ARP studs did you use?
Thanks!
Old 06-01-2014, 07:19 PM
meflyfrc
meflyfrc's Avatar
Thanks!
I purchase the hubcentric spacers from www.motorsport-tech.com
I purchase 3-1/4" studs from JEGS and cut them to 2-5/8". Here is a pic next to the stock stud. The yellow mark is where I cut the stud.
Here they are installed.
Old 06-01-2014, 09:57 PM
968ls1
968ls1's Avatar
Default Studs and spacers
Thank you for the detailed response! Did you remove the hub/upright or drill a hole in the backing plate to install the studs?
Old 06-02-2014, 11:05 AM
skull
skull's Avatar
Stock c5z wheels clear. I have my stock 18s on the front and 17s in the rears. Or you can do 18s all the way around. Require no modification. Just a narrow front tire for the 18s. I have 275 40 18 fronts. Have had zero issues. Soon to get forgestar wheels tho
Old 06-02-2014, 01:01 PM
meflyfrc
meflyfrc's Avatar
I remove the hub. I think it is faster than trying to drill a hole in the backing plate and then thread a bolt through the hole.
Old 06-03-2014, 09:30 PM
scott88
scott88's Avatar
Default ttt
Is anyone running a 18/19 setup with big brakes? I have started looking at wide fenders but I am still looking for wheels that would fit
Old 06-03-2014, 09:57 PM
meflyfrc
meflyfrc's Avatar
The setup in my pics are 18/19.
Old 06-03-2014, 11:32 PM
skydiven4fun
skydiven4fun's Avatar
St. Jude Donor '13-'14-'15
Mine are 18/19 TSW Nurburgring, plenty of clearance
Old 06-04-2014, 08:45 PM
scott88
scott88's Avatar
Default ttt
Your car looks good with the wheels and other black trim
Old 06-05-2014, 12:00 PM
rjs209
rjs209's Avatar
Check out Ace Alloy "Slick" wheels 18 front and 18 or 19 rears. They are available from several of the usual Corvette p[arts guys.
I have the 18/18 set up. No issues and they look great.
You can find a ton of pic's of C5's with them.
Old 06-05-2014, 11:45 PM
skydiven4fun
To C5 w/c6 zo6 brakes.... What size and offset?
Quick Reply: C5 w/c6 zo6 brakes.... What size and offset?
