Tail light lens removal?
Tail Light Lens Removal
Received 3,812 Likes
St. Jude Donor '03-'04
Removing the lens from the rear fascia is a simple matter of using a#15 torq driver to remove the two screw that hold it to the fascia.
Some how , I think you are asking about opening the housing itself. It has been sealed in its manufacturing process. It's not an item that can be opened easily. This is Radioflyer ( a forum vendor ) area of expertise. You can contact him and ask him.
Received 19,309 Likes
'20-'21-'22-'23-'24
That's the question I think he is asking and I agree that the RadioFlyer is the one to ask. Good luck. Let us know what advice he gives you.
I would think its not much different then opening headlights which I have done several times...lay a cookie sheet in your oven at 225 degrees place a damp towel on top of the cookie sheet...place your light on top of the towel so you don't melt the housing, bake for no more then 5 mins or less, then have some gloves handy, and some plastic tools or flat blade screw drivers, then very carefully pry the two surfaces apart from one another
I used a band saw cut them apart put LED inside glued them back in 2010 haave had no problems
