2001 C5 build
2001 C5 build
Well i have decided to build the car i have , a 2001 Base model .
The work is being done at Next Episode Garage in Dothan Al
The tuning will be done by Derek at Browning tuning once the install is complete
It will be a twin turbo 408 .
Turbos- Turbonetics 6165.
Custom install done by
Custom grind cam by Brian Tooley
Clutch - Monster LT1-R
Engine - Texas Speed custom built Forged LSX 408
25-TSP408SB-X - Texas Speed & Performance Custom
Built Forged LSX 408 CID
186-APO31V-DS - Callies Dragonslayer
4.00' Stroke Crankshaft, 24X Reluctor Wheel
10-K456X3 - Wiseco Piston Set: 4.030' Bore
x 4.0' Stroke x 6.125' Rod Length; 1.110'
CD, -20cc Dish; Includes Wrist Pins & Steel
Top/Napier 2nd Ring Set
NoPRings - No Extra Piston Rings Required 1ea
46-234-5608 - ARP Main Stud Kit for
LS1/LS6-Based Engines
76-00106 - Joe Gibbs Break-In Oil, 15w-50
wt., 1 Quart
25-Mach - Full Block Work and Preparation:
Vat & Clean Block, Line Hone, Install New
Cam Bearings, Bore/Hone with Torque
Plate, Balance Rotating Assembly, Square
Deck & Set Deck Height, Engrave with Serial
Number & TSP Logo, Set Ring Gaps, Prep
Connecting Rods
171-CB-663HN - Clevite LS1 H Rod
Bearing,
25-DTS - Windage Tray Spacer for Stroker
Motors
28-19260093 - GMPP LSx Standard-Deck 6-
Bolt Iron Block
28-1453658 - GM Transmission Dowel Pins 2ea
25-TSP6125-IB-8 - Texas Speed &
Performance 6.125" Super I-Beam
Connecting Rod Set with ARP 2000 Bolts,
Set of 8
171-MS-2199H - Clevite H Main Bearing
Set, For LS1 Stroker Applications
10-S718 - Wiseco Piston Wrist Pin, .927 x
2.250, .200 Wall Thickness, Straight Wall,
9310 Material, PER WRIST PIN
199-PRCLS36B260 - Precision Race Components
Aftermarket LS3 260CC CNC Cylinder Head (pair)
Camshaft:
customer supplied cam
25-LBKit-X - Texas Speed & Performance Kit for GMPP
6-Bolt LSx Long-Block Assembly
Raw Good
53-72332LUN - Lunati Street Performance
Link-bar Hydraulic Roller Lifters
25-TCG - Timing Cover Gasket 1ea
25-FCS - Front Cover Seal 1ea
25-novalleygsk - No Valley Cover Gasket
Needed (Comes with New Valley Cover)
1ea
46-234-2503 - ARP LS1 Harmonic Balancer
Bolt
1ea
28-12617944 - GM LS1 Exhaust Manifold
Gasket
2ea
28-12612350 - GM LSx Oil Pan Gasket 1ea
25-WPG - LSx Water Pump Gasket, Pair 1ea
46-134-1003 - ARP LS1/LS2/LS6 Camshaft
Bolt Kit
1ea
25-TSPLS6PortedPump - TSP LS6 Ported
Oil Pump
1ea
202-H2570SP9051S - Cometic LSX Head
Gasket: 4.140' Bore, .051' Thickness, 6-Bolt
Provisions, LEFT GASKET
1ea
202-H2569SP9051S - Cometic LSX Head
Provisions, RIGHT GASKET
1ea
46-234-4319 - ARP Head Stud Kit for LSx
Block - 6 Bolts Per Cylinder
1ea
25-7500-1 - 7.500' Length Pushrods, 5/16',
Single
16ea
11-CS1180 - Rollmaster LS2 Single Roller
Timing Set - 1X Cam Gear
1ea
6 Sale 28-12570471 - GM LS2 Valley Cover $ 119.99 1 ea $ 119.99
7 Sale 135-LS2-CSAH-2 - Racetronix Cam Sensor Harness
Extension *Plugs in to Pigtail*
8 Sale 135-LS2-KSRH - Racetronix Knock Sensor Harness
Extension
9 Sale 28-12633906 - GM LS2 Timing Cover Assy.: Includes
Cover, Gasket, Bolts, Cam Position Sensor, and Sensor
Harness
10 Sale 25-LS3RockerUpg - Texas Speed Trunion Upgraded
LS3 Rocker Arm Package
GM LS3 Intake Manifold
GM LS2 Throttle Body
Racetronix LS2 Throttle Body Adaptor
Harness,
ARP LSx Intake Bolts, Chromoly, Black
Oxide, Hex Head, Set of 10
GM L92/LS3 Intake Manifold Gasket Set,
Includes 8 O-Ring Gaskets
wt., 1 Quart
Connecting Rods
Bearing,
Motors
Bolt Iron Block
Set of 8
Camshaft:
Raw Good
1ea
Bolt
1ea
Gasket
2ea
Bolt Kit
1ea
Oil Pump
1ea
1ea
1ea
1ea
Single
16ea
1ea
Extension
Harness
Harness,
Received 19,460 Likes
'20-'21-'22-'23-'24
Lots of new stuff there but it should be one heck of a beast when you are done.
That's a great start , I envy your project. I'm not quite there yet. Are you running a auto or manual trans, the reason I asked is that now your going to be making more serious HP, are you going to be doing any upgrades to your drive train (clutch,rear-end,etc.) ? Good luck !!
I am installing a Monster LT1-R Clutch now . Gonna stick with the stock transmission and rear diff until they let go. Then i will be going with a RPM transmission and diff.
Not to many pic's right now . Just a couple of a torn down car and a few of some parts that have arrived . We will order the engine next week . We are relocating the battery to the rear of the car and the cpu and fuse panel to under the dash on the passengers side.
Fuel system will be upgraded to a return system with Deatsch Works 95lb injectors.
I am going to the shop tonight after work and will try to get pic's of everything that will be used on the car . That we have already.
I was told by Scoggins Dickey to get what I want as far as HP even the stock iron block would be the weak point in the build. So we upgraded to the LSX Block. This engine will be built to handle 25psi of boost.
Custom install done by Go-Autoworks.
wt., 1 Quart
Connecting Rods
Bearing,
Motors
Bolt Iron Block
Set of 8
Camshaft:
Raw Good
1ea
Bolt
1ea
Gasket
2ea
Bolt Kit
1ea
Oil Pump
1ea
1ea
1ea
1ea
Single
16ea
1ea
Extension
Harness
Harness,
wt., 1 Quart
Connecting Rods
Bearing,
Motors
Bolt Iron Block
Set of 8
Camshaft:
Raw Good
1ea
Bolt
1ea
Gasket
2ea
Bolt Kit
1ea
Oil Pump
1ea
1ea
1ea
1ea
Single
16ea
1ea
Extension
Harness
Harness,
What are your goals for RWHP and RWTQ? What are you hoping to get?
Thanks,Matt
Looking for 1000rwhp. I have been told this setup is capable of more. I will be running pump 93 octane. If E85 was more available in my area I would run that. My tuner says we could get more out of it on E85 and still be just as safe as less on 93.
Former Vendor
wt., 1 Quart
Connecting Rods
Bearing,
Motors
Bolt Iron Block
Set of 8
Camshaft:
Raw Good
1ea
Bolt
1ea
Gasket
2ea
Bolt Kit
1ea
Oil Pump
1ea
1ea
1ea
1ea
Single
16ea
1ea
Extension
Harness
Harness,
wt., 1 Quart
Connecting Rods
Bearing,
Motors
Bolt Iron Block
Set of 8
Camshaft:
Raw Good
1ea
Bolt
1ea
Gasket
2ea
Bolt Kit
1ea
Oil Pump
1ea
1ea
1ea
1ea
Single
16ea
1ea
Extension
Harness
Harness,
