Throttle body cleaning?
Old 05-10-2016, 04:52 PM
Vanover
Vanover's Avatar
Default Throttle body cleaning?
Should I remove the TB and clean it,or is it ok to leave on and clean it?
Old 05-10-2016, 05:36 PM
Vanover
Vanover's Avatar
Old 05-10-2016, 06:57 PM
Bill Curlee
Support Corvetteforum!
Bill Curlee's Avatar
Received 2,180 Likes on 1,583 Posts
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Take the entire induction system apart from the filter box to the Throttle Body. Clean the MAF with MAF cleaner and then clean the throttle body BLADE
Put it all back together and make SURE all the ducting is 100% sealed up so NO unmetered air gets in.
Once your done, you will be certain ALL is CLEAN...
BC
The following 2 users liked this post by Bill Curlee:
Fed Up (05-10-2016), Vanover (05-10-2016)
Old 05-10-2016, 07:00 PM
Fed Up
"My Dad's a TV Repairman"
Fed Up's Avatar
BC
Sealing is huge; I had a very slight idle issue when warm, and it turned out that the flex coupling between the bellow and TB was loose, and the snap clamp even looser. Sealed it up with some black RTV and reclamped. Idles like a stone.
Old 05-10-2016, 07:01 PM
Evil-Twin
Evil-Twin's Avatar
Received 3,812 Likes on 1,925 Posts
St. Jude Donor '03-'04
Don't touch the wires in the Mass air sensor and TB area with anything other than this:
Old 05-10-2016, 07:53 PM
Vanover
Vanover's Avatar
Thanks guys.knew how to clean the MAF,just wasn't sure how deep to go in the TB.didnt want to spray to much in there and screw something up.did my truck first,before I did my car just to be on the safe side.all is good and can tell a diff.thanks for the help.
Old 05-11-2016, 01:08 AM
striper
striper's Avatar
At Walmart, I recently purchased a set of small spray cans of throttle body cleaner and MAF cleaner from CRC. Cost about $8. I'm going to take my complete intake apart and clean everything, I have a Callaway Honker.
To Throttle body cleaning?
Quick Reply: Throttle body cleaning?
