Cigarette Lighter Fuse?
Old 05-03-2005, 04:00 PM
VetteVinnie
Support Corvetteforum!
VetteVinnie's Avatar
Received 1,681 Likes on 1,070 Posts
Default Cigarette Lighter Fuse?
My 2003 manual and fuse layout is different from my mother-in-law's 2001 coupe, and she does not have an owner's manual. The cigarette lighter is dead (but the auxilliary charger under the console works). Is there a seperate fuse somewhere for the dash cigarette lighter? Or is the element dead? Any help is appreciated. Thanks!
Old 05-03-2005, 04:35 PM
GMTB3
5th Gear
GMTB3's Avatar
I dont know if this will help, but I replaced my cigarette lighter and auxillary power fuses a couple of weeks ago, and they were located in the fuse box, not the one in the engine, but under passenger side floor mat. You have to remove your floor mat and peel back the carpet. Now, I have a '99 so I dont know, but hope this helps. Also, cheapest place i have found for owners manuals is Helm Inc., not sure of the website though.
Old 05-03-2005, 04:41 PM
VetteVinnie
That will help, yes. I wasn't even aware of the box under the carpet even in my own Vette. Thanks.
Old 05-03-2005, 07:22 PM
vetred
vetred's Avatar
If it turns out that isn't the fuse I will relate my li'l two cents,.........When I installed the hurst shifter I had to unplug the ciggie' lighter, When I put everything back together I felt the wire connection was awfull loose,....................Ya, I was right I know that I did it right but the wire didn't stay pluged in I now wonder if it is so loose that it could vibrate off over time, on its own????????
Old 05-03-2005, 08:24 PM
Bill Curlee
Bill Curlee's Avatar
Received 2,180 Likes on 1,583 Posts
CI 6,7,8,9,11 Vet
St. Jude Donor '08
It is fuse # 07. It reads C/LTR (20 amp) It is in the Instrument panel Electrical Center.
BC
Old 03-08-2011, 04:52 PM
C5-Generation
C5-Generation's Avatar
Checked cigarette light in ashtray area - it works. I only saw a square yellow fuse connected to a device - with Air Bag stamped on it. Console lighter also works.
All fuses 10 - 40 amps work as tested, engine and floor. I could not test the black square shaped fuses.
Should I pull out the cluster and replace the bulb. Is it solder in?
Old 03-08-2011, 04:55 PM
Sea Five
Sea Five's Avatar
what the heck was I doing 6 years ago....
lucky131969
lucky131969's Avatar
This thread is almost 6 years old. I assume you are trying to troubleshoot the check engine light issue, which I provided you a link, to the schematic, and full service manual procedure. What are you trying to do?
Old 03-08-2011, 05:56 PM
imavettegirl
imavettegirl's Avatar
hahahahahahahahahahahahahahaha ha!
LOL!
Old 03-08-2011, 05:59 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Old 04-30-2014, 05:48 PM
Euthanizer
Euthanizer's Avatar
St. Jude Donor '09
lol old thread helps my dumb @ss figure out why my cigg lighter didn't work
To Cigarette Lighter Fuse?
Quick Reply: Cigarette Lighter Fuse?
