Check Engine Light...No codes?
Old 06-28-2006, 09:05 PM
D_BlueVette
D_BlueVette's Avatar
Default Check Engine Light...No codes?
Got the check engine light last week. Pulled the codes today but all I find are History codes "H" codes. Shouldn't I be finding a code that ends with the "C" for the current code? I'm confused. Can anyone help a novice out.
Thanks in advance.
D_BlueVette
Old 06-28-2006, 09:10 PM
screw991le
screw991le's Avatar
Location: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
If the CEL comes on and goes out, then yes, it would a history code. Was the CEL steady on, when you pulled the code?
Old 06-28-2006, 09:17 PM
Ranger
Support Corvetteforum!
Ranger's Avatar
Originally Posted by D_BlueVette
Got the check engine light last week. Pulled the codes today but all I find are History codes "H" codes. Shouldn't I be finding a code that ends with the "C" for the current code? I'm confused. Can anyone help a novice out....
Transitory CEL is common.
Pulling the codes is good practice. H codes came reflect transitory events. The Cs are of more concern.
Temporary commo issues are the most common when a processor doesn't receive a report from a sensor at the expected interval.
Another is a lean code if you have an aftermarket intake.
In the FAQ sticky is a list of the codes and their meanings. Suggest you look them up and post questions if any are unclear.
Ranger
Old 06-29-2006, 02:45 AM
SFVetteman
SFVetteman's Avatar
This is sad but true...some history codes can be current as well Sometimes I think the engineers do this as some kind of joke but that's what the manual says about some of the codes.
Old 06-29-2006, 08:13 AM
runamuk
runamuk's Avatar
Cruise-In V Veteran
St. Jude Donor '04
If you erase the code it will turn the check engine light out or you can just wait and the light will probably go out on it's own.
Old 06-29-2006, 11:01 AM
D_BlueVette
Yes, the CEL was steady on when I pulled the codes. The CEL has been steady on for a week now?
Old 06-29-2006, 11:52 AM
Ranger
Ranger's Avatar
Hard for anyone to assist unless you post the codes.
Ranger
Old 06-29-2006, 04:16 PM
dougbfresh
dougbfresh's Avatar
The CEL light can go on (I think) if one of the gauges goes into the danger zone also-what are your gauges saying?? This may/my NOT trigger a stored code.
Old 06-29-2006, 04:31 PM
FormerBiker
FormerBiker's Avatar
Make sure the gas cap is on tight....it happened to me.
Old 06-29-2006, 04:35 PM
Dirty Howie
Dirty Howie's Avatar
This is true.
At track when I get CEL for getting temps too high there is NO code !!
DH
Old 06-29-2006, 05:12 PM
D_BlueVette
All other gauges are giving good readings. give me a few minutes and I'll post some codes.
Old 06-29-2006, 05:20 PM
D_BlueVette
These are the only codes I found. Would any of these give me a check engine light since they are all History codes?
10-PCM P1870 H
60-IPC B0521 H
U1160 H
B0-RFA U1096 H
U 1064 H
U1016 H
Old 07-01-2006, 12:50 PM
D_BlueVette
10-PCM P1870 H
60-IPC B0521 H
U1160 H
B0-RFA U1096 H
U 1064 H
U1016 H
TTT
Old 07-01-2006, 01:12 PM
vettenuts
vettenuts's Avatar
If you shut down the motor and then turn the key to pull codes, they will be history codes. If you pull codes but don't shut down the motor they are likely "C" codes. Found that out last night with my rich bank 1 code I am trying to figure out.
Old 07-01-2006, 01:50 PM
Ranger
Ranger's Avatar
10-PCM P1870 H
60-IPC B0521 H
U1160 H
B0-RFA U1096 H
U 1064 H
U1016 H
10-PCM (Powertrain Control Module)
P1870 H....Transmission Component Slipping
60-IPC (Instrument Panel Cluster)
B0521 H....Tachometer Signal Circuit Malfunction
U1160 H....Loss of Communications with LDCM
B0-RFA
U1096 H....Loss of Communications with IPC
U1064 H....Loss of Communications with BCM
U1016 H....Loss of Communications with PCM
None of those would concern me except P1870, which I'll not seen before and can't help with. I would clear all the codes and then go for a drive. Then recheck. Commo codes are usually based on transitory events.
Here is a useful site to bookmark:
2002 Chevrolet Corvette OBD-II Codes
Ranger
Old 07-01-2006, 09:05 PM
Dirty Howie
TTT
The 1870 transmission slipping is cause you have an A4. It may be going out. Do you have a custom tune? Are you getting hard shifts?? What are your tranny temps???
DH
Old 07-02-2006, 07:08 AM
D_BlueVette
DH
I noticed some hard shifts about four or five different times the other day while cruising around town. Didn't really think about it much because the hard shifting stopped and hasn't been back since.
I do not have a custom tune and I'll have to check my tranny temps, pretty sure its not running too hot, but I will check.
Thanks guys.
To Check Engine Light...No codes?
Old 07-02-2006, 07:36 PM
Dirty Howie
Thanks guys.
Well my tranny just died today
It slips in 3rd and 4th .... barely got home !
......... and NO CODES !!!!
DH
Old 07-02-2006, 10:53 PM
D_BlueVette
DH
I hate to hear that about your tranny . My tranny temp is running about 140. I have no idea what normal running temp is. What do you all think?
Old 07-03-2006, 04:49 PM
Dirty Howie
140 is excellent !! Now go drive the car hard in the heat for 20-30 minutes and report back your tranny temps .........
DH
Quick Reply: Check Engine Light...No codes?
