svc tire mon system??!
Cruise-In II Veteran
Cruise-In III Veteran
i got this message this morning also got low tire pressure.
but have never seen service tire monitoring system before what is that about??
Re: svc tire mon system??! (zeus337)
You might need a new tire sensor. It means a sucky trip to the dealer. :U
btw,Do you miss your Hardtop?
[Modified by BRADS C5, 9:53 AM 10/9/2001]
A trip to the dealer was how mine got fixed. There are some "how to's" here on the Forum about retraining your sensor(s) that you might try. Good luck!
SAVE THE WAVE :seeya :flag
Re: svc tire mon system??! (motoracer)
it is not doing it now could the cold weather have caused it like it caused the low tire pressure reading.
one thing though the dealer changed the wheels on my car when i bought it so could that have something to do with it he upgraded me with polished ones from another car?
Re: svc tire mon system??! (BRADS C5)
my next car will definetely be a hardtop.
i had to trade it because a dealer damaged the body on a oil change and the zo6 was to $$$ so i went with the coupe, but a zo6 is my next vette.
love your car!!! :cool:
Zeus, If the dealer changed your wheels and did not re-program all 4 sensors after they put the new wheels on, there is your problem. Just use the re-learn process that is in your owners manual. I learned that from the best tech on this board....C5TECH :D
Re: svc tire mon system??! (pkmoose)
will this also cause the svc tire mon. system.
the system has worked fine for 3 mths after the dealer changed out wheels until other day :confused:
Re: svc tire mon system??! (Corvette Poor)
i have not seen the msg until other day 2 or 3 mth after dealer swapped wheels :confused:
it popped up again this morning and it was cold and frosty out. does cold weather affect this like it does tire pressure levels??? :confused:
