Help Royal Purple ATF
Old 02-01-2008, 04:05 PM
Old Rotor Head
Old Rotor Head's Avatar
Default Help Royal Purple ATF
I replaced the trans fluid in my '99 MN6 last weekend with Royal Purple. The shifting has gotten stiffer, down shifting is almost impossible. If it effected the paper barriers are they gone and need replacing or will changing fluid help?
Old 02-01-2008, 04:24 PM
FKING1
FKING1's Avatar
I put Redline D4ATF, which is similar to RP, in my 00 M6 5 years ago and it continues to shift just fine.
Old 02-01-2008, 07:02 PM
burbleflyer
burbleflyer's Avatar
St. Jude Donor '08
I put RP in my '00 six speed last year and it made shifting easier. I cured my morning reverse shift difficulties completly.
ETA: I did not use RP ATF, I used their manual trans stuff.
Old 02-01-2008, 07:38 PM
Oldvetter
Oldvetter's Avatar
I would change to Amsoil ATD or ATF and see. It immediately fixed my grinding 6th gear 1998 using Mobil 1 ATF when I changed fluid.
Old 02-01-2008, 09:49 PM
SUPERCRUZ
SUPERCRUZ's Avatar
I think you need to get the RP ATF out and put in RP Synchromax, Redline D4 or Redline MTL, or Amsoil. I am running the Redline D4 product in my MN6. Good luck with it.
Old 02-01-2008, 10:31 PM
John Galt
John Galt's Avatar
If the paper barriers are gone, you are SOL. Changing fluid at this point will not help.
Still, I would try changing anyway to see if it helps, because it may be that the barriers are not gone.
Old 02-01-2008, 10:57 PM
jedblanks
jedblanks's Avatar
I don't think your issue is RP ATF, I used it and RP rear end oil. Both have been fine for 1 year and 10,000 miles. This is in a 1997 MN6
Old 02-02-2008, 12:01 AM
striper
striper's Avatar
I hope you didn't use RP ATF. They make a specific fluid for manual trans cars that require ATF. It's called Synchromax. I have it in my car a couple of years and it shifts perfectly. I tried a couple of other brands and the RP was the smoothest.
Old 02-02-2008, 12:36 AM
rhneff
rhneff's Avatar
You might want to check out this thread:
http://forums.corvetteforum.com/show...26&forum_id=49
RP recommends both RP ATF and RP Synchromax for standard transmissions requiring a Dexron III type fluid, but suggests Syncromax offers higher performance.
That said, I couldn't find the thread but do recall some time ago reading one on the forum that said the friction material on the sychros used in early C5 transmissions was different than on later models but I can't recall what year it changed. It's possible the OP's 1999 model uses the older type material and could have been damaged by the fluid.
As another posted suggested, best action would be to drain the RP completely and re-fill with GM fluid to see if things get better. If the synchros have been damaged it won't help, but you might get lucky.
Old 02-02-2008, 09:16 AM
WKMCD
WKMCD's Avatar
I run RP in my 98 transmission with great results.
Old 02-02-2008, 09:33 AM
Old Rotor Head
Thanks guy's. Switched back to Mobile1 and all is well. Looks like I used the wrong RP, RP AFT Max not Sync.
Old 02-02-2008, 11:51 AM
C66 Racing
Premium Supporting Vendor
C66 Racing's Avatar
These are the fluids to which Oldvetter is referring:
AMSOIL ATF
AMSOIL Torque-Drive Synthetic Transmission Fluid
I've been using the ATF in my 02 Z06 on the track for years without any issues.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Ordering Information (Retail sales using reference #1206638 benefit the forum.)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
AMSOIL Catalog
To Help Royal Purple ATF
Quick Reply: Help Royal Purple ATF
