Serpentine gatorback too short?
Old 05-06-2008, 09:29 AM
bgspot
bgspot's Avatar
Default Serpentine gatorback too short?
I purchased the gatorback a/c and serpentine belts yesterday. Thanks to write ups from BowTieRocket, TheeMike, and others the process was a breeze except for one problem. The serpentine belt seems a tad too short. I tried slipping it under the water pump last and i tried slipping it over the tensioner pully last. Neither worked for me. After a couple hours of fighting with it i put the old belt back on. A/c belt was a breeze. Anyone else have trouble with this belt? Part number is 4060798.
Old 05-06-2008, 10:20 AM
Benpup
Benpup's Avatar
Cruise-In VI Veteran
Have one sitting in the back of my car with the old one back on too. I gave up after an hour of pinched fingers etc. I kow I have the right one but I'll be darmed if it will slide on. Super tight. Afraid it will rip my balance off.
Old 05-06-2008, 10:44 AM
corvettebob1
corvettebob1's Avatar
Try removing the top bolt form your alt. and loosing the bottom bolt and push the alt. top towards the engine. Then put the belt over all the pulleys except the idler next to the power steering slip it over this idler last and then pull back the Alt. and reinstall the top bolt and tighten the lower one.
Old 05-06-2008, 12:00 PM
SteveDoten
SteveDoten's Avatar
Cruise-In VII Veteran
R2 installer if the belt is correct size
this is basic stuff, use the smooth wp pulley as the last one to slip over
Old 05-06-2008, 02:55 PM
bgspot
bgspot's Avatar
Thanks for the replies, will give it another go when i get home.
Old 05-06-2008, 03:09 PM
Benpup
Benpup's Avatar
Me too.
Old 05-06-2008, 06:12 PM
bgspot
bgspot's Avatar
Tried your method as soon as i got home and it WORKED like a charm!
Corvettebob1 you're the man !
Old 05-06-2008, 11:05 PM
Bubbletop409
Bubbletop409's Avatar
Originally Posted by Benpup
Me too.
P-51 Mustang, Cadillac of the sky must have been very exciting to have a famous fighter in your family, congrats.
To Serpentine gatorback too short?
Quick Reply: Serpentine gatorback too short?
