Got tired of my ugly LSx... Decided to make it look a little nicer
Old 04-06-2009, 12:17 AM
Mike94ZLT1
Mike94ZLT1's Avatar
Default Got tired of my ugly LSx... Decided to make it look a little nicer
Let's face it. While Gen III and Gen IV are some of the best engines ever made, they are also some of the ugliest.
Well, I decided to do something about that. I tore the top off my motor, and started hacking apart my wiring harness. I pulled all the tape off, and all the nasty plastic wire loom.
I put my new TPIS intake on, that I had sanded and smoothed last week, along with a 90MM LS2 throttle body. I also started doing the plumbing for my billet fuel rails that I had powder coated red to match the throttle body and katech valve covers
I then started cutting and splicing things where I wanted them to go, and splicing in some LS2 wiring bits as well, since I think adapters are ugly.
Working on some more of the plumbing:
Mike94ZLT1 is offline
Old 04-06-2009, 12:19 AM
Mike94ZLT1
Mike94ZLT1's Avatar
I then started wrapping all the wires in this split braid flex loom stuff I got from Jeg's. I also put my Katech valve covers on, and relocated my EVAP system to clean things up.
So thats what I got done today. Tomorrow I'm going to finish with my wiring harness, make my brackets to mount the coils in the fenderwells, and clean a few more things up. Anyways, just wanted to share, sorry for the crappy camera phone pics.
Special thanks to SilentFright (Matt) for all his help! I saw his, and was inspired to do something similar. Thanks to RoadRebel / Dr. Phil too, for answering my dumb questions on a sunday
Old 04-06-2009, 12:47 AM
vsocks1
vsocks1's Avatar
Looks a lot better already!
vsocks1 is offline
Old 04-06-2009, 07:13 AM
Eric D
Support Corvetteforum!
Eric D's Avatar
St. Jude Donor '09-'10-'11
Mike!
Hey, thanks for sharing the photos and info on your engine face-lift.
I am very interested in how you will relocate the coil packs. I'm thinking of doing a project much like yours this coming winter when I do the cam, heads, intake and exhaust system.
Nice Post!!
Eric D is offline
Old 04-06-2009, 07:52 AM
Bertram65
Bertram65's Avatar
Looks nice, how did you splice the wires without ending up with bulky connectors where the splices are?
Bertram65 is offline
Old 04-06-2009, 07:54 AM
WKMCD
WKMCD's Avatar
Looks good. I really need to make the time to do some wire management on mine.
WKMCD is offline
Old 04-06-2009, 08:19 AM
clemsondave
clemsondave's Avatar
Looks great! Ever thought about painting the intake?
clemsondave is offline
Old 04-06-2009, 09:30 AM
SilentFright
SilentFright's Avatar
Location: Arlington Texas, originally from San Angelo, TX
Pimp daddy Mike. Looks awesome bro!
SilentFright is offline
Old 04-06-2009, 09:37 AM
95BlueBomber
95BlueBomber's Avatar
Looking Nice!
Those valve covers are real nice
95BlueBomber is offline
Old 04-06-2009, 09:38 AM
Mike Mercury
Mike Mercury's Avatar
that's my next mod; cleaning up the wire bundles. And now I have a template to use
Mike Mercury is offline
Old 04-06-2009, 09:58 AM
DIXZ
DIXZ's Avatar
A great improvement!
DIXZ is offline
Old 04-06-2009, 10:58 AM
Mike94ZLT1
Mike94ZLT1's Avatar
I cut the wires the length I wanted them, slid heatshrink tubing over the end, and twisted the wires together neatly. I then soldered them, and moved the heat shrink over the joint. I used a cigarette lighter to shrink it, and it came out great!
Old 04-06-2009, 12:39 PM
Eric D
Eric D's Avatar
Just as a FWIW, solder joints in cars are not a good idea. The vibration associated with the vehicle environment will cause over time (sometime very short time) embrittlement of the joint causing it to fail. This is the reason you will find crimped connections from the OEM in place of solder joints. A better joint can be made by using crimp connectors (splices) along with your shrink tubing to cover the splice. I normally apply clear RTV over the splice and then slide the shrink tubing over it and shrink it before the RTV sets up making a good water tight connection.
Eric D is offline
Old 04-06-2009, 12:42 PM
itzza427
itzza427's Avatar
Nice work,,,You have a lot more nerve and patience than I have!! Really looking good!!
itzza427 is offline
Old 04-06-2009, 06:23 PM
Stevo92z28
Stevo92z28's Avatar
Looks great, now just get rid of the cheap autozone special breather and it'll look perfect.
Stevo92z28 is offline
Old 04-06-2009, 07:01 PM
csexton
csexton's Avatar
Looking good
Chuck
csexton is offline
Old 04-06-2009, 07:18 PM
TooMch
TooMch's Avatar
I'm interested in this. What kind of crimped connectors do you use? Crimp butt splices?
TooMch is offline
To Got tired of my ugly LSx... Decided to make it look a little nicer
Old 04-06-2009, 07:42 PM
ColeTrain'sC5
ColeTrain'sC5's Avatar
i'm gonna be relooming my whole engine bay. it'll stay black but i do wiring of GPS systems on metro transit vehicles(buses and such) and am good at that stuff. I need to organize everything under the covers and engine bay. Needs to get done O/P awesome job man that looks great. I'd love to see where you relocate the coils
ColeTrain'sC5 is offline
Old 04-06-2009, 07:46 PM
Eric D
Eric D's Avatar
The ones I use are called "heat shrink butt splices". As mentioned earlier, I like to add RTV to the open ends before shrinking to help keep moisture out. I have also used a hot glue gun to help seal the ends after shrinking, but it takes longer then the RTV and is a little more messy to deal with.
Eric D is offline
Old 04-06-2009, 07:47 PM
lucky131969
lucky131969's Avatar
If your going to suggest the crimp connection, you should at least promote the correct type environmental splice and crimper. Much more efficient than a butt splice/rtv/heatshrink, takes up less space, and is approved for automotive and aviation purposes. Environmental splices also allow multiple repairs without staggering depending on the wire diameter.
lucky131969 is offline
Quick Reply: Got tired of my ugly LSx... Decided to make it look a little nicer
