SOHC to DOHC conversion kit? true??
Did any of you guys hear about DOHC conversion kit for the ls1 i saw one on eBay i just wanted to ask if it fits on our cars and if any of you guys used it and if did was there a huge difference in power?
Batten.
Batten was one of the companies that used to do four valve heads for a number of different blocks. Not sure if they ever made one for the LS, there was just never enough reason for people to get these even for older much less efficient SBC motors. The LS doesn't need OHC of any type for the very small improvement you might get in some areas, not for all the negatives that come with OHC's also. The Batten heads were on the cover of Hot Rod a few times. There where a few others but most where billet one offs. Then there is the old Eagle motors which where insane but not really street engines.
It only works if you add VTEC, and bump the rev limiter to 9800 RPMs so you can really feel the VTEC.
You need a boost gauge on the A-Pillar too to dial in the vacuum setting and to make sure you don't run too much vacuum.. Although some is good. On a cold day.
ok guys take it easy on me i forgot that ls engines have a single cam my father has a C4 ZR1 and im just used to that cars engine and the way its bulit and and plus have always owned cars with over head cams and i got used to sayin that it’s a mistake that can happen with anyone so take it easy on me im still gettin used to a vette
Banned Scam/Spammer
Received 1,319 Likes
I used to see ads in Hot Rod magazine back in the early '90's featuring (expensive) 4 valve head conversions for Gen1 small blocks...
It was a novelty then, and it remains as an overly complex pipe dream today.
Whoa... Is this a Viper forum? Why is everyone jumping on this kids nuts for asking a question? I thought we were supposed to help each other out with problems and answer questions, not ridicule each other and tell people to go drive something else, like we are elite and better than them.
Chuck
