ZO6 LS6 internal engine question
Old 01-30-2010, 04:44 PM
torkman15
torkman15's Avatar
Default ZO6 LS6 internal engine question
Question of the day, yes I searched.
When did GM start putting the full floating wristpins in ZO6 LS6 engines? I thought 2005 ??? I'm in need of a couple (2) stock LS6 pistons with rods and the ones I'm replacing are full floating (2005 CTS-V)
Thanks, Tom
Old 01-31-2010, 08:44 AM
torkman15
torkman15's Avatar
Tough one isn't it. Somebody knows....
Old 01-31-2010, 09:57 PM
torkman15
torkman15's Avatar
No winners yet
Old 01-31-2010, 10:23 PM
~Josh
Banned Scam/Spammer
~Josh's Avatar
Received 1,319 Likes on 788 Posts
It's my understanding that the LS2 engine got the floating pins.
The Corvette-spec LS6 was identical from '02 through '04.
*edit: Google searching found this thread that said 2005 LS engines got the floating pins and piston durability should be more than the 200,000 miles of previous engines among other benefits.
Scroll down a bit, it has a section just about the pins.
http://www.fastfieros.com/enginesava..._ls1ls2ls6.htm
Old 02-01-2010, 12:10 AM
turbinesurgeon
Cruising
turbinesurgeon's Avatar
I could be mistaken, but I don't think the LS6 ever got full floating pins in production.
The LS6 is the evolution in the LS1, which had press-in pins. Engine ran 2001-04 in the vette, and 2004-05 in the caddy. I have detailed books on the LS6 up to 2003, and they were press-in. The only factory mods done to the engine that I know of were in 2002, when they improved the block breathing and cam profile.
Tear down your block and look at the pins on your good cylinders. If they are free-floating, the only reason I can think of is aftermarket. If they aren't, stock LS1 pins are interchangeable.
Old 02-01-2010, 01:42 PM
torkman15
torkman15's Avatar
I guess I have the only factory freak LS6 with floating wristpins...not really, GM did it just not very long. Sometime in 04 and continuing thru 05 until the LS2 started going in Caddys they put floating wristpins into LS6s using the LS2 style bushed rod. My best contacts at GM are scratching their heads but will get back with me.
Old 02-01-2010, 01:45 PM
torkman15
torkman15's Avatar
This engine has a vin stamped in it and it looks like it only ran for a min or two, bearings look out of the box new.
Old 02-01-2010, 03:55 PM
SDPC
Premium Supporting Vendor
SDPC's Avatar
BTW, that's the same part number piston as the 05 CTS-V LS6 piston. GM shows none in stock
__________________
800-456-0211 / PM /E-mail Facebook AIM or Yahoo: JSSDPC
SDPC since 1929 thanks to you guys! WHIPPLE Superchargers, Procharger, Magnuson,
Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, Yella Terra, HPTuners, 7.400" pushrod set (other lengths available)
Old 02-01-2010, 06:25 PM
turbinesurgeon
Cruising
As I said, I could be wrong. My good info stops at 2003. Interested to see what you find out
Old 02-03-2010, 12:07 AM
torkman15
torkman15's Avatar
Looks like late in 04 and all 05 LS6s got floating wrist pins and just use the LS2 bushed rod.
Old 02-04-2010, 10:52 AM
Eric D
Support Corvetteforum!
Eric D's Avatar
St. Jude Donor '09-'10-'11
From my data the LS1 and LS6 had floating wrist pins starting in 2004 production as with the small block v8 truck line of engines.
Old 02-26-2018, 06:01 PM
Bilster
Bilster's Avatar
Reviving this thread to mention I just purchased a 2005 LS6 rotating assembly with floating pistons.
Old 07-26-2019, 09:55 AM
wydopnthrtl
wydopnthrtl's Avatar
From my research it looks like "late 04" got floating pins. My Z06 was made in March of 04.. I'd really like to know what I have.
Old 07-26-2019, 07:25 PM
Brackets
Brackets's Avatar
My '05 CTS-V has floating pins.
To ZO6 LS6 internal engine question
Quick Reply: ZO6 LS6 internal engine question
