Poly Control Arm bushing Rebuild
Old 02-21-2010, 12:08 AM
Its_Go_Time
Its_Go_Time's Avatar
Default Poly Control Arm bushing Rebuild
There have been quite a few threads started regarding the use of polyurethane control arm bushings. In my humble opinion, after good tires, nothing will improve the handling of your vette as dramatically as poly control arm bushings. They provide a smoothly pivoting, bearing-like joint, and reduce unwanted motion in other directions. Unfortunately, they need a LOT of maintenance to function properly. The lubricating grease gradually works itself out of the bushings, causing them to bind up and make noise. I have found that I can get about 7-8 months of quiet daily-driving before they begin to groan. I don't drive the car during the winter, so I have plenty of time to re-grease them, but it's still a mega pain in the ***. The following is a general rebuild procedure for VBP poly bushings, though others are probably similar. If you're thinking about these for your car, read through this and ask yourself if you're ready to do this on the regular...
Here's the front right upper arm, straight off the car. This arm has about 8 months of daily driving and one long road trip on it since it was last overhauled. As you can see, the grease tends to ooze out over time, drying out the working surfaces inside.
First thing to do is give it a bath in the parts tank, and remove as much of the crud as possible. If there's one good think about the lube leaking out of the bushings, it really protects the arm from the elements...this arm is 8yrs old, driven daily.
Once it's clean, the bushings can be disassembled. Its a good idea to use soft jaws in the vice to prevent marking the soft aluminum shaft. Simply remove the circlip, lift off the washer and then the arm with the bushing still in it. To remove the bushing from the arm, push it out with your thumbs, or tap it out with a hammer/socket.
Here's the shaft with the bushing removed. Notice the almost complete lack of greese.
This is what a front-upper arm looks like completely disassembled. If I can make one suggestion...have a supply of extra circlips on hand. They have a tendency to distort somewhat during removal.
Here's an interesting feature of the VBP bushings. This is an end view of the pivot shaft. These can be bolted up to the car with either the short or long side against the frame. With the short side against the frame, you can achieve the same range of camber adjustment as OEM. Mounting them with the long face against the frame gives you a boatload of extra negative camber, making agressive track alignments easy to achieve.
Here's what happens when the bushings dry up...material begins to transfer from the bushing to the shaft. Once this process begins, moaning and groaning is right around the corner. Before the bushing can be reassembled, this build-up must be removed.
Simply run some 600 grit paper soaked in varsol over the shaft like this. Remove ALL traces of build-up, but try and avoid removing aluminum from the shaft.
After years of experimenting, these are the two lubes which have worked the best for me. Not great, but good enough. Permatex Copper Anti-Seize on the shafts, and Loctite ViperLube full synthetic greese in the bushings. If anyone knows something that works really well, speak now.
Here's the shaft, lubed with anti-seize. Don't forget to lube the thrust surface as well!
...and here's the greased bushing, pushed back into the arm.
Finished front upper arm. Note that the bushings press in from the outside in. The shafts are inserted with the flanges to the outside.
Front lower arm. The bushings in this are representative of all the bushings in the rear, so I'll only show how to do these...the rears are done the same way.
The first thing to do after the arm has been cleaned is seperate one of the outer washers from the center shaft. The easiest way to do this is to insert a pin punch or screwdriver into the center hole and knock against the shoulder of the washer. Once one washer is off, pull the other off with the center shaft still attached. If it doesn't slide out easily, knock it out from the other side with a long socket.
Once the side washers and center shafts are out, the bushings can be removed from the arm. The bushings are in 2 pieces, pressed in from either side. This makes it hard to get to the back of the bushing to knock it out. I made this tool to sneek into the gap between the bushing halves.
Here it is in position. I just tap on the end with a small ball peen hammer to push the bushing out. Once one half is out, the other half can be knocked out with a socket.
The arm, completely disassembled. Note how the washers have raised flanges in the center which press into the shaft to hold them in.
These steel shafts can pick up material from the bushings as well...make sure you clean them well.
I use the same lubricants on these bushings as well. When I apply the grease, I try and work as much as I can into the groove between the two halves. When I take the arms off in the winter, the front-lowers NEVER squeak...maybe this extra grease is why.
Once everything is lubed and assembled the washer needs to be pressed back into the shaft. This is all it takes. Just crank on the vise as hard as you can. When you have it clamped like this, you can really appreciate how smoothly these bushings operate. Note: make sure the bushing halves with the wide flanges go towards the outside...if you mess this up, the arm won't fit the crossmember any more.
Front lower arm finished.
Still reading? Only six more to go!
Old 02-21-2010, 01:19 AM
SebringSixSpeed
SebringSixSpeed's Avatar
Good write-up. I plan on getting poly bushings eventually and this is good to know. Thanks.
Old 02-21-2010, 02:21 AM
randy814u
randy814u's Avatar
Thanks for the info.
Old 03-08-2010, 11:06 AM
cwalsh
cwalsh's Avatar
Good write up. What are you using to get the arms so clean? Also for lube have you heard of Super Lube? I got it from Spohn Performance many years ago for my F-Body's Poly bushings. resists water washing it away.
Lube Link
Super-Lube Manufacturer Link
Chris
Old 03-08-2010, 04:33 PM
Its_Go_Time
Lube Link
Chris
I just cleaned them in a varsol parts cleaning tank...They're pretty greasy by the end of the summer, and I guess that keeps em looking fresh underneath. Thanks for the heads up on the grease...I'm done for this year, but maybe I'll give it a shot next winter. I've found the front-uppers to be the worst groaners by far. How did ur F-body fare with this stuff?
Old 03-08-2010, 05:22 PM
Fast one
Fast one's Avatar
Why don't you put grease fittings on?
Old 03-08-2010, 05:27 PM
ericdwong
ericdwong's Avatar
Great write up. I had Poly control arm bushings they were fun while they lasted but once they got noisy, after all the hassle on a daily driver, I took them off and went back to rubber
Old 03-08-2010, 05:29 PM
Mark C5
Mark C5's Avatar
St. Jude Donor '08-'09-'10
Great write up, thanks for taking the time and effort. Have you considered teflon tape instead of grease?
Old 03-08-2010, 09:00 PM
Its_Go_Time
I'm scared The cross-section around the bushings is so thin, I don't really feel comfortable machining into it. Besides, I doubt the grease would spread evenly around. Theres pretty much no clearance between the shafts and bushings.
I do this for my sway bars and it works great! The sways have split bushings that kinda "wrap around" the bars, so its easy. With these bushings, you have to slide the center shafts into the bushings, which would just scrape the tape off...
Old 03-08-2010, 09:25 PM
postwhore
postwhore's Avatar
does anyone make real bearings for that application ?
Old 03-08-2010, 09:41 PM
Its_Go_Time
Pfadt makes a set using spherical bearings. I think they run about 2 grand.
Old 03-09-2010, 02:52 AM
postwhore
postwhore's Avatar
I was thinking roller/needle bearings rather than heims.
Old 03-09-2010, 11:42 AM
cwalsh
cwalsh's Avatar
It does work real well. It leaves a thick film. I had used it for my LCA's, panhard bar and torque arm. I would grease them maybe once a year and it was truely a daily driver in the snow and rain.
Good write up.
Chris
Old 03-09-2010, 06:29 PM
leadfoot4
leadfoot4's Avatar
Received 1,343 Likes on 1,094 Posts
Lube Link
Chris
Just my $0.02 worth...I've been using either Energy Suspensions' grease of SuperLube for a LONG time, both with good results.
Old 03-09-2010, 07:59 PM
Bill Curlee
Support Corvetteforum!
Bill Curlee's Avatar
Received 2,180 Likes on 1,583 Posts
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I have this project on my list. Great write up. It going on my C5 Post everybody must have!
Bill C
Old 03-09-2010, 09:48 PM
Its_Go_Time
Bill C
Thanks Bill.
Mods that frighten passengers are good...but ones that frighten the driver are the best . Getting the old rubber out will be the worst part of the job. You'll need a press to do it properly.
Old 03-09-2010, 10:11 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Thanks Bill.
Funny you should say that. I went on a Cruise to Bear Mountain NY with the Northeast Pack a couple of years ago and we did some SERIOUS mountain road carving. That day I learned a LOT about my suspension and cars capability. I pushed it to some very far limits and felt the rear-end suspension bushings not being happy.
New POLY Bushings should be REALLY COOL!
Yea,,,,Ive scared quite a few people in the right seat.
I let my son drive my ZO6 when he came home on leave from the Army and we were going to dinner. He was at a light and we needed to make a left turn. He started off in a normal every day start form the light and about half way thru the intersection, he NAILED the throttle and power slid thru the turn. I about S%*@ my pants.
He looked at me and laughed and said "See how it feels being the PASSENGER!" After I regained my composure, I had to laugh.
Chip off the olé block!
Bill C
To Poly Control Arm bushing Rebuild
Old 03-10-2010, 12:41 AM
postwhore
postwhore's Avatar
Thanks Bill.
$100 at Harbor Freight
Old 03-10-2010, 09:27 AM
ajg1915
ajg1915's Avatar
St. Jude Donor '08
Zert fittings work well and will shoot the grease where it's suppose to be on the inner side of the bushing between the inner bushing and metal sleeve.
Looks like this.
Old 03-10-2010, 09:37 AM
Independent1
Independent1's Avatar
St. Jude Donor '08
^^Not a very good idea for a street-driven vehicle. Great way to go for a track driven only car.
Quick Reply: Poly Control Arm bushing Rebuild
