Engine advice
Any time I reuse heads, I have a machine shop pressure test them and then mill the surfaces to ensure they're true. Money well spent.
In your case with the bent valves, I'd strongly consider just buying a set of new ones from a sponsor.
Darn shame on the hack job install but it's good you're fixing it right.
St. Jude Donor '09-'10-'11
Was the engine over rev'd? What harmonic damper is on the engine? As others have already suggested, get the heads reworked. Maybe a good time to do a cam if you want a little more out of the engine along with new valve springs. Make sure you use new head bolts. Sorry to hear that your engine bit the valves, that sucks!
I plan on using new head bolts, but if I put them on a straight edge and they are true with no stretched threads why am I replacing them ? I know the rule of thumb but I hate spending money...I plan on taking the heads in thanks for the advice. Now to find a good Machine shop in Ontario
You missed some of the questions in the earlier post, they are important, unless you don't mind doing this all over again.
