Help - Popup Lights won't go down?
Old 03-30-2002, 02:11 PM
lundgren
lundgren's Avatar
Default Help - Popup Lights won't go down?
I was testing to find the running-lights lead, and while messing around, turning lights on and off, now, the headlights are UP, and won't go down? They turn on and off, but won't 'retract'.
Also.. I don't think my yellow running lights, or rear running lights come on.
I'm thinking fuse, but I cannot find it.
Help!
Old 03-30-2002, 03:17 PM
lundgren
lundgren's Avatar
Default Re: Help - Popup Lights won't go down? (lundgren)
Found it.... a fuse.
Old 03-30-2002, 03:30 PM
CP
CP's Avatar
Received 1,125 Likes on 562 Posts
Was it blown? :confused:
Old 03-30-2002, 06:40 PM
lundgren
lundgren's Avatar
Default Re: Help - Popup Lights won't go down? (CP)
Yeah.
Old 03-31-2002, 01:40 PM
Uncle Bud
Uncle Bud's Avatar
While replacing bulbs in my "E" lights recently I had almost the same problem. Except it only affected the operation of the 'down' motion. If I manually turned them down they would come up and light when I turned the lights back on. I couldn't figure it out.... Then, after waiting for awhile things just started working correctly... Damned if I know... :)
Old 03-31-2002, 10:39 PM
chuck1026
chuck1026's Avatar
Cruise-In II Veteran
Default Re: Help - Popup Lights won't go down? (Uncle Bud)
That sounds like a thermal breaker (like in a hair dryer)... Maybe it tripped after multiple motor cycling and then auto-reset itself after cooling down???
To Help - Popup Lights won't go down?
Quick Reply: Help - Popup Lights won't go down?
