Check engine light???
Old 10-24-2010, 03:25 PM
plumberh2o
plumberh2o's Avatar
Default Check engine light???
got a code of 10 PCM PO-492 I have no way of telling what this code is telling me?
Does enyone know off hand?
Old 10-24-2010, 03:51 PM
ZeeOSix
ZeeOSix's Avatar
What year Vette is this on? I can't find the P0492 OBDII code anywhere.
I did find this thread that has info on P0492.
http://forums.corvetteforum.com/c5-t...-question.html
Old 10-24-2010, 04:23 PM
plumberh2o
plumberh2o's Avatar
2004 coupe.Kencan
ok now I know that it is an air pump with a leaking check valve.
where do I look for them, under the hood or under the car.
I will get some carb cleaner and take care of this as soon as I can find the check valves location.
I am a pretty good with repairs once I get to the right part.
Old 10-24-2010, 05:36 PM
plumberh2o
plumberh2o's Avatar
bump upstill need help to find these check valves.
Old 10-24-2010, 06:02 PM
dougbfresh
dougbfresh's Avatar
You need to learn how to search here-do an advanced search on it!
Old 10-24-2010, 08:21 PM
robsc501
robsc501's Avatar
Hi There,
The check valve is located just below& to the left of the brake booster.Do a forum seach type: How to replace the(p1416) air check valve.
Bill Curlee tells you what to do & Patches has a picture of the AIR valve.
robsc501
Old 10-25-2010, 04:12 AM
ZeeOSix
ZeeOSix's Avatar
Originally Posted by robsc501
Hi There,
robsc501
So what's the difference in the way the car tests and senses that causes a P1416 or a P0492? Both are for passenger (bank 2) AIR system fault.
http://forums.corvetteforum.com/1557595860-post6.html
Old 10-25-2010, 07:12 AM
lucky131969
lucky131969's Avatar
None. The code changed in 2004, the test routine is the same.
Old 10-25-2010, 04:49 PM
ZeeOSix
ZeeOSix's Avatar
Interesting ... I didn't know the codes changed in 2004. I guess as time goes on, more and more 2004+ Vettes will suffer from AIR check valve failures and we'll be seeing more P0492 codes along with the P1416 for the earlier models.
To Check engine light???
Quick Reply: Check engine light???
