C1232 LF Wheel Speed Circuit Open or Shorted
would this code be the reason my active handling and abs lights are on, on the dash? only code i pulled besides was a tpms code for no sensors.
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Unless theres some sort of obivous phisical damage to the wheel HUB,, I HIGHLY doubt that theres ANYTHING wrong with it.
90% of the WSS issues are caused by damaged female connector pins in the jumper harness or the connector the jumper harness plugs into on the frame K member.
If you have female pins that look like this,,, thats part of the issue!!! The one on the RIGHT is hosed and needs to be bent back in shape with a pick or replaced!
BC
BC
Received 8,928 Likes
The ABS, TC and AH cannot function if one of the wheel speed sensors isn't working properly. They all need to know what that wheel speed is in reference to the other 3 wheel speeds.
Bill
So I swapped out the wheel sensors that you said. Just switching rf to lf for each other and the code went off.. Traction and active handling is gone! I haven't driven anywhere yet but I think it worked? Im not sure why switching sides would turn it off. If it comes on again atleast I know I just have to replace those!
so the abs and active handling light went off on the dash. but now when i go above 60 traction control comes on and it kills the gas.. i turn off the TC and it drives just fine. the only codes i pulled up was the tire pressure sensors but thats because i dont have any installed other than that theres no other codes. im guess its the wheel sensor harness need to be replaced? sound right?
Ask me how I know.
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Is your steering wheel pointed DEAD NUTS STRAIGHT when the car is going straight down a level straight road????
Your yaw accelerometer could be having issues or your Steering Wheel Position Sensor is bad.
BC
for the most part its pretty straight but does steer to the right very very slightly..
if it was one of those wouldnt a code go off? i pulled the codes and there wasnt anything...
whats my next move in diagnosing this?
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Why would a DTC be set for the car reacting to a NORMAL response. Your wheels are pointing STRAIGHT but your steering wheel is pointing in a DIFFERENT direction. The car is applying braking correction to get the car to go in the direction that the STEERING WHEEL is pointing.
If you have TC issues, it would be a Whees Speed Sensor Issue and the car thinks the wheels are loosing traction or are spinning at different speeds. Sounds like the signal for one of the wheel sensors is not correct.
My recommendation would be find out how and when the wheel started to point in an off center when going straight situation. (could be parts / could be alignment related) and or We issues.
When it acts up again, please note any and all DIC Messages.
BC
BC
