2000 procharged vette wrecked at autocross computer got wet PLease help
Old 05-06-2011, 03:49 PM
Dace
3rd Gear
Dace's Avatar
Default 2000 procharged vette wrecked at autocross computer got wet PLease help
Hello,
New to the wonderful world of owning my first vette. I baught the car already modded this is what I know its a 2000 auto under 20k, procharged 9psi,msd fuel booster,and ignition.Kn air filter and some other goodies for the body. Here is the story had the car a month(OCT 2010) and was invited to an autocross( thought great run the car and be safe ) wrong hit some dirt on the track went sideways thought the car would stop hit sand and pebbles..... went over a 8 inch curb into about 2 feet of water at a 4 foot angle or so. hooked the car up pulled out but water hit the ecu and fuse box on passenger floor.When we went in i killed the key immediately and got out. Towed the car after unhooking the battery and took my wife to the hospital...Well friend of the family owns a body shop left it all winter not bad rockers and bumper scuffed up.Drove it 2 weeks ago before all back together and ran great surprisingly. Parked it and had everything put back together... drove it 10 miles got about half throttle and it was good... at 55 punched it about 3\4 throttle maybe 2 seconds let off and coasted went to give it gas and nothing.... 1st and 2nd good 3 gone... stopped by autozone battery was shot.. installed new one. did oil change and procharger oil change. went through wrote down all the codes and cleared them. here the are all history codes no current • DTC P0134 HO2S Circuit Insufficient Activity Bank 1 Sensor 1
• DTDTC C1255 EBTCM Internal Malfunction
• C P0480 Cooling Fan Relay 1 Control Circuit
• DTC B0432 Rear Defogger Relay CircuitDTC B0503 RH DRL Relay Circuit
• DTC B0507 LH DRL Relay Circuit
• DTC B0508 LH DRL Relay Circuit
• DTC B2483 Backup Lamp Relay Circuit
• DTC B2587 Column Lock/Unlock Drive A
• DTC B2588 Column Lock/Unlock Drive A
• DTC B2592 Column Lock/Unlock Drive B
• DTC B2593 Column Lock/Unlock Drive B
• DTC B2721 PASS-Key Detection Circuit
• DTC B2723 PASS-Key Detection Circuit
• DTC U1001-U1254 Lost Communication with XXX (U1016)(U1040)U1096 (U1064)
• DTC U1000 and DTC U1255 Class 2 Communication Malfunction (U1000)
• DTC B1001 Option Configuration Error
• DTC B2252 Key Cylinder Switch Circuit
• DTC B2282 Battery #1 Circuit
• DTC B2283 Battery #1 Circuit
• DTC B2284 Battery #2 Circuit
• DTC B2285 Battery #2 Circuit
• DTC U1255 Serial Data Line Malfunction
any help would be appreciated... you can also email me mike@raswith.com thanks
any thoughts will help tricks ...
so i am asking could this be a computer issue... how can i check it..
battery issue.. did not have time to check fluid in tranny... or is the tranny shot if so live in Ohio if you know a good place do get a tranny please list it. something beefed up would be good like to hit corners more than straights. thanks again
Old 05-07-2011, 09:25 AM
AntonioZ06
AntonioZ06's Avatar
well, it seams like you did the right things about letting the car dry out. However I think that once wet, all the ground points have corroded and rusted over. I'd start with that first, and clean each and every one of them. You can look in the tech section in the electric problem sticky and they have a diagram of all the ground points on the car. I guess start with that, and let us know if anything changes
Old 05-07-2011, 12:47 PM
rebelheart
rebelheart's Avatar
You make no mention of trying to actually take things apart and drying them out(fuse box,bcm etc) if you just left the car sit,you will now have never ending electrical problems.
Old 05-07-2011, 01:50 PM
C5kid
C5kid's Avatar
Cruise-In VI Veteran
St. Jude Donor '12
agree Antonio... start checking the grounds. Chances are the PCM may have gotten wet internally. Check the passenger sidefoot well PCM also. My PCM got wet in there from that lovely A/C drain that GM never cut and mine did the same thing.
Drove fine, threw a bunch of codes. Turned the car off and BAM she was dead. What really sux is if you get a new PCM the dealership will have to flash it to match it to the BCM and they will put a stock 2000 tune in the car. So keep that in mind also, you will have to contact a tuner or purchase a tuning software to get a S/C tune back in the car.
Old 05-09-2011, 01:26 AM
Dace
3rd Gear
Dace's Avatar
Hello, Thanks for your help great place to start I will post how it goes as soon as I get some progress. Also C5kid when you say yours did the same did you mean the tranny acted up too? Thanks again!!!!!
Old 05-09-2011, 05:49 AM
C5kid
C5kid's Avatar
St. Jude Donor '12
no I was takling about the PCM throwing all those codes and crap. Any water on those PCM's creates a nightmare.
Old 06-15-2011, 02:31 PM
Dace
3rd Gear
Dace's Avatar
Ok so I eneded up taking the car to a shop were they pulled apart the fuse box, and computer went over the wiring cleaned all the corrison said that's all good now but it will not shift in to 3rd or 4th still the said they are not tranny specialist but they think its internal and said to have it checked.could the wreck or water caused something to fail if so insurance will have to pay for it. But if not I will I can get a reman tranny for 1500 bucks.or do I have a shot of it being fixable if so any ideas what its doing or what could of caused it. Thanks
Old 06-15-2011, 03:38 PM
Bill Curlee
Support Corvetteforum!
Bill Curlee's Avatar
Received 2,180 Likes on 1,583 Posts
CI 6,7,8,9,11 Vet
St. Jude Donor '08
WHOH!!!!!!!!!!!!!!!
Before yoyu jump into trans repairs,,,, CLEAR ALL the DTCs! Then POST what comes back!! The trans will report issues like the ones your having. well actually the PCM will report them but you get the picture.
BC
To 2000 procharged vette wrecked at autocross computer got wet PLease help
Quick Reply: 2000 procharged vette wrecked at autocross computer got wet PLease help
