Auto Transmission fluid Change
#61
bump for trans fluid
Yep. The method of disconnecting the outbound line to the cooler has been my preferred method for long time. I tow a 5 ton boat with my truck, so the 20 qts of fluid gets changed every season. I will note, however; I designed a beer bong with a r&r'd coat hanger hook about 6 ft long clear vinyl tube and a nipple to add fluid in the side plug. I hang it from a step ladder near the car, so I can see it from all angles. (I use a similar setup as a one man brake bleeder, which is very very effective). I also use a mirror to monitor the plug hole. I keep a catch pan underneath. no muss no fuss.
#62
Quality synthetic transmission fluids are designed for 50k mile change intervals under severe conditions, which would include your truck, if it's maximum tow rating is not exceeded.
#63
Huge drain pan under the transmission and run the car.
No need to disconnect any cooler line.
