Fog Light switch and trunk switch not working
1st Gear
Just purchased a 2000 c5 convertible and the fog light switch and trunk switch on the left side of the steering wheel are not working. The key fob trunk button works fine, but neither of the 2 buttons work in the car work. Any help?
Check to see if the plug is off.
My fog lights did not work when i got mine this year and it ended up being a relay under the hood, but i agree with 65 if both are not working it might be unplugged.
Mine werent working when I purchased my vert eithere... But one day I disconnected the battery for about an hour and when I hooked it back up it started wroking again and has been working ever since!
Hope its a easy fix like mine was....
That fog/trunk switch assembly just pulls out of the dash. Use a small flat blade screwdriver to pry it out part way if you need to. There's a connector back there with a couple of wires in it that's probably loose. Check to make sure it's in tight. Let us know if it works.
Congrats on your purchase
1st Gear
Pulled out the entire switch and everything is plugged in. Still nothing. Disconnected battery. That didnt do anything but reset all my radio stations lol. When I push the unlock button on key fob, fog lights come on for a few seconds. Both buttons still wont work though.
Hi guys
Having same issue.
Just disassembled the entire dash to fix the AC actuator, and then reassembled the dash.
Everything working fine except the buttons that open the trunk and the fog lights (switch left to steering wheel).
I have made sure the switch is connected and also attemped changing the 15amp fuse without any luck. Also disconnected and reconnected battery.
Any tips to next steps of fault searching?
Having same issue.
Testing Fog Light / Trunk Switch.
I don't know about the rest of the switch, but on mine it was obvious that the diode was blown. You can test the diode with an ohmmeter, it should have continuity in one direction but not the other. It's easy to spot as it's black and round.
