Texas Speed 224r Cam question
I have Installed a Texas Speed 224R 581/581 114 Cam and I can't get rid of the valve train noise. Does anyone else have this cam with the same problem?
Mods are TEA Stage 1 heads with Beehive springs, LG Street Pro LT's, Fast Intake, and the Texas Speed Cam
I have the right size push rods installed with about 0.80 preload on LS7 lifters and it's still ticking. If its the nature of the beast then I guess I have to live with it, but I don't like the noise.
My 228R from Texas Speed and Performance sound track listening to valve train noise!
http://www.youtube.com/watch?v=QydZ7OOroTs
Pardon my Obama impersonation...Uhhh...Uhh...Uhh.
Where do you hear the noise? With the hood open and you listening? Or while driving? If it is while driving, it may just be the valves echoing through the header (normal). If it is noticable with the hood open, you may have measured PRs incorrectly.
I have that exact cam in my 97. Yes I have a clicking noise. Had it for about 5 years and many track days. I took AU N EGL advice about two years ago and went LT headers, no cats, and muffler bypass. Now that beautiful sound kind of out weighs the clicking noise
This is what I did, and from what I've read the lifters I'm runnining need about .080 of preload
use the Comp, which is 6.800" closed.
How to use
Each turn of the pushrod is 0.050". When fully closed, it is 6.800". This is pushrod "gauge length" so you can't measure it directly as the pushrod length is actually based on the length between the ball ends where the ball end measures 0.140" in diameter. Assuming you are using stock rockers or a non-adjustable rocker.
1. Open the adjustable pushrod to the same length as your stock pushrods
2. Close it down two turns
3. Put your rocker rail on the head
4. Make sure you cylinder (typically #1) is at top dead center on the firing stroke so both valves would be closed
5. Put the pushrod in place on the intake valve and make sure it is in the lifter cup
6. Install the rocker and snug down the bolt (don't need to torque, just make sure it is snug)
7. Lift rocker tip up and down, if it "ticks" the pushrod is too short. If you can't easily move the rocker the pushrod is too long.
8. You can try and adjust the pushrod in place but my fingers are too fat so I end up pulling the rocker and adjusting the pushrod length. Go either shorter or longer 1/2 turn and try again.
9. You are trying to get to the point where the lifter doesn't "tick tick" with the pushrod in place nor is the rocker snug. When you get the pushrod length such that you just barely get rid of the "tick tick", you have found "zero lash".
10. When you have found zero lash, carefully remove the rocker and pushrod without rotating the pushrod.
11. Tighten the pushrod until it is fully closed counting the turns as you go.
To figure out your pushrod length you do the following. Let’s assume it took 10-1/2 turns to close the pushrod down to its shortest length after you reached zero lash. Each turn is 0.050".
Your length is then: 6.800" (fully closed length) + 10.5 X 0.050" (number of turns times the length change per turn) = pushrod length minus preload. So for this case:
6.800 +10.5 X 0.050 = 7.325"
This is the length you measured to zero lash without any lifter preload. Now let’s say you want to have 0.100" lifter preload, you add that to the measured number and you end up with 7.425" pushrod.
How to use
Received 2,054 Likes
The XER lobes of that cam although not extremely high lift are very agressive on the opening/closing rates off the seat which adds to valvetrain noise.
At 0 lash at #1 cly @ TDC I was 8 1/2 truns out on the PR checker which is .425 added to 6.800= 7.225+ .80 preload is 7.305 I intalled 7.300 rods. So I guess I'm okay, but the noise drives me
When you say stock are you talking no headers or CAI?
Zip tie "cai", the headers are soon to be installed ARH 1 3/4 long tubes and non-catted x-pipe running thru a stock LS1 catback.
I know you said that you measured the pushrod length, but if you're using stock heads (unmilled) and stock gaskets - there's no way that the right size pushrod is shorter than stock. In order to get that level of lift, the cam grinder has to make a smaller base circle cam. For me the difference between the stock cam and the Comp cam was 0.102" for base circle diameter. Divide that by 2 and I should be running an extra 0.050" pushrod over factory 7.400". I had already purchased 7.425" and that's what I'm going with.
That said - my car isn't back together yet.
