Synthetic brake fluid
Old 04-30-2012, 08:17 PM
MR.G.
MR.G.'s Avatar
Default Synthetic brake fluid
I have the posts about synthetic brake fluid NOT being able to absorb the moisture. If changed REGULARLY is synthetic fluid ok or should I steer clear of it altogether?
Thanks,
Mike
Old 04-30-2012, 09:10 PM
LoneStarFRC
LoneStarFRC's Avatar
Location: Dear Karma, I have a list of people you missed.
Any brake fluid, "synthetic" or otherwise, is fine for your car as long as it says "DOT3" or "DOT4" on the label. Castrol, Valvoline, Prestone and Amsoil (among others) each offer a synthetic brake fluid.
Perhaps you are thinking of silicone based brake fluid, which is a DOT 5. While it's true that it is very non-hygroscopic (doesn't absorb moisture easily), DOT 5 should NOT be used.
I prefer the DOT 4 since it typically has a higher wet boiling point than DOT 3.
HTH
Old 04-30-2012, 09:19 PM
Bill Curlee
Support Corvetteforum!
Bill Curlee's Avatar
Received 2,180 Likes on 1,583 Posts
CI 6,7,8,9,11 Vet
St. Jude Donor '08
100% on the mark!!! D O NOT USE DOT 5!!
I have used and perfer SYNTECH Dot 4
Old 04-30-2012, 10:52 PM
spdislife
spdislife's Avatar
Thanks,
Mike
Depends on what you're going to use your car for. If it's spirited driving DOT 4 will be plenty. I track my my car and use Motul 600.
Old 04-30-2012, 11:00 PM
piran21
piran21's Avatar
Anyone running Castrol SRF?
Old 05-01-2012, 07:21 AM
leadfoot4
leadfoot4's Avatar
Received 1,343 Likes on 1,094 Posts
HTH
To Synthetic brake fluid
Quick Reply: Synthetic brake fluid
