I have the posts about synthetic brake fluid NOT being able to absorb the moisture. If changed REGULARLY is synthetic fluid ok or should I steer clear of it altogether?
Thanks,
Mike
Any brake fluid, "synthetic" or otherwise, is fine for your car as long as it says "DOT3" or "DOT4" on the label. Castrol, Valvoline, Prestone and Amsoil (among others) each offer a synthetic brake fluid.
Perhaps you are thinking of silicone based brake fluid, which is a DOT 5. While it's true that it is very non-hygroscopic (doesn't absorb moisture easily), DOT 5 should NOT be used.
I prefer the DOT 4 since it typically has a higher wet boiling point than DOT 3.
Thanks,
Mike
Depends on what you're going to use your car for. If it's spirited driving DOT 4 will be plenty. I track my my car and use Motul 600.
