jacking up c5 for about 5 hours
Quick question...been reading up on proper jacking and bracing the vette for jack stands. I am only lifting long enough to paint calipers. Is it ok to lift by the jacking poinnts for this small amount of time???
2 birds, errr wheels with one stone
And depending on the caliper paint, I believe its only good for a fairly short time - -just put all 4 up at once
St. Jude Donor '05-'08
For the rear you can jack by the cross member and do both of the rears at the same time assuming your jack is rated for that amount of weight..
Yes, you can jack up one side at a time using the jacking points without a problem. I'd suggest the front point because you can lift both wheels at once.
Having the car on a jack only isn't a safety concern as long as you're not putting body parts under the car or suspension that could be fallen on. I do it all the time, to the point I installed aluminium rails on the frame so I could just jack on the rail right in the middle of the door. They also save the rockers from dragging.
