Service steering column
Old 03-02-2014, 01:25 PM
theDudeabides
theDudeabides's Avatar
Default Service steering column
I'm exasperated. The last few days everytime I start my my 2000 C5 I get the "remove key wait 10 seconds". Then the "service steering column", then no can drive. A few times if I wait awhile and hit the key fob lock, unlock, lock, unlock and start the car I'm good to go. This vehicle according to Chevy had the steering column recall done in 2004. The steering column is not locked when I get the message, Chevy dealer says the lock is thrown but the "gear lock size" has been changed so it isn't locked. So apparently the computer thinks it's locked and shuts off the gas at 2 miles per hour. Chevy dealer says it's a $400.00 to $500.00 dollar fix not sure and won't know unless they hook it up to a machine then they'll know better and the machine charge is $100.00. HELP what should I do? Also I've read posts on here about this issue but don't quite understand how to apply that to my particular problem.
Old 03-02-2014, 01:31 PM
corvettebob1
corvettebob1's Avatar
Clear your codes in the DIC then check your battery voltage level, should be 13.2v fully charged if not charge the battery and check it again.
99.9% of column lock issues are caused by low battery voltage.
Old 03-02-2014, 01:33 PM
tacman
tacman's Avatar
St. Jude Donor '13
See the "sticky" at the top of this Forum page. Should answer your questions.
http://forums.corvetteforum.com/c5-t...ky-please.html
Old 03-02-2014, 03:33 PM
theDudeabides
Originally Posted by 8VETTE7
I agree that the battery being low or the battery connections being loose or corroded can cause the column lock symptoms.
Suggest that you purchase and install an LMC5 to get around the problem. DO NOT let the dealer touch the car. GM has NEVER EVER had a permanent solution to this problem and has walked away form even trying to provide C5 owners with one.
A CLB or LMC5 will correct the issue permanently and is something you can install yourself.
I don't know what an LMC5 or a CLB is ? Which is best and what do those initials stand for ?
Old 03-04-2014, 08:56 PM
Chilliwack vettes
Chilliwack vettes's Avatar
I bought the LMC5
http://www.complianceparts.com/
Old 03-04-2014, 09:41 PM
theDudeabides
Default Yes to the LMC5
Originally Posted by Chilliwack vettes
Yeah, I bought one the other day, hoping I get it tomorrow. I can't wait to see if this works.
thanks
Old 03-05-2014, 08:00 AM
johnnyzvette
johnnyzvette's Avatar
It will work, i had the same problem with my car last year, installed the lmc5 and got it running again! Just follow the directions carefully.
Old 03-05-2014, 06:21 PM
theDudeabides
Default Eureka
I GOT THE LMC5 TODAY AND IT WORKS !!! You do have to follow the directions carefully but Richard is great if you have any questions. The dealer had done whatever he did and stuffed the modified column lock relay up under the dash. It took some pinched and scratched fingers to dig it out.
Thanks to everyone on the forum and kudos to Richard at Compliance Parts, he knows his sh t.
Old 03-05-2014, 11:53 PM
scarecrowkc5
scarecrowkc5's Avatar
Quick question, I bought a 2002, 80k miles LS1 and the steering wheel has no lock, I can turn it freely. Does this mean that a previous owner has already done the repair?
Thanks!
Old 03-06-2014, 12:08 AM
Bubbletop409
Bubbletop409's Avatar
Thanks!
Just because the lock is removed, you can still have an electric glitch that will put the computer into safe mode that shuts off the fuel pump. Have a tuner reset the shut off MPH, dealers will not do it, they'd rather charge you for something that will fail again.
Old 03-06-2014, 09:46 AM
wcsinx
wcsinx's Avatar
Rich is awesome. And the LMC5 is a great product.
Old 03-07-2014, 08:08 AM
theDudeabides
Default freaking column lock
what 8VETTE7 said https://www.corvetteforum.com/forums...ies/iagree.gif
To Service steering column
Quick Reply: Service steering column
