Main Cigarette lighter
Old 08-01-2014, 07:50 PM
weykool
weykool's Avatar
Default Main Cigarette lighter
I know this is small and probably petty to some, but I am working through everything top to bottom on my newly purchased 2002 Vette. The main cigarette lighter will not work. I did my research and located the fuse under the floor panel on the passenger side. That 20amp fuse is fine. I pulled it to check it and put it back in and the lighter still won't work. The lighter in the console works just fine but I would like to use the main lighter plug for my Valentine 1. Can anyone suggest where I should check next?
Thanks,
G
Old 08-01-2014, 08:14 PM
65GGvert
65GGvert's Avatar
Received 3,220 Likes on 2,302 Posts
I'd check that the wire that plugs on to the back of the receptacle is still plugged in. IF it is, I'd measure the voltage on that wire. If it's not there, I'd go back to the fuse box and look for another fuse.
Check fuse 1 and fuse 7. One says cigarette lighter, the other says console cigarette lighter. Don't know which is which.
Old 08-01-2014, 08:36 PM
weykool
weykool's Avatar
Okay, fuse 1 and 7 are both good, so we have eliminated that possibility. Is there an easy way to get to the back of the lighter wires or will this require removing the console just to get back there?
Old 08-01-2014, 09:18 PM
weykool
weykool's Avatar
This is a small thing I am sure. Fuses are good put I have no power to the cigarette lighter for some reason. Is there a simple way to remove or access the back of the cigarette lighter to check the wiring? I don't want to remove a bunch of console parts just for the cigarette lighter.
Thanks,
G
Old 08-01-2014, 09:23 PM
Bill Curlee
Support Corvetteforum!
Bill Curlee's Avatar
Received 2,180 Likes on 1,583 Posts
CI 6,7,8,9,11 Vet
St. Jude Donor '08
You have to remove the console. On other way to access it
Old 08-01-2014, 09:32 PM
weykool
weykool's Avatar
Can you tell me where to find removal instructions?
Old 08-02-2014, 12:03 AM
K9Leader
K9Leader's Avatar
Vette Essentials has some good instructions that cover console removal. Here is a link to one of those: http://www.vetteessentials.com/instr...t_install.html
You'll get good at removing the console after you've done it a couple of dozen times. Ask me how I know.
K9Leader
Red cars are faster.
To Main Cigarette lighter
Quick Reply: Main Cigarette lighter
