Check valve broken, code thrown, related?
My car wasn't starting on the first try so I hooked up a fuel gauge and found out that it was not holding fuel pressure after the car was turned off. Which made it seem like the check valve is bad, I have not replaced it. Now it is throwing code P0171 H - Fuel trim system lean bank 1, are the two related? Is it okay to drive it as is?
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Bill
St. Jude Donor '14
P0171 is probably a vacuum or air leak. Check the pcv system and MAF connections. I had to replace the check valve in my 2000, it's tricky. Be careful not to kink the plastic lines!
