Camber plates on 2001 c5z
Old 01-31-2016, 01:09 AM
blake-anderson
blake-anderson's Avatar
Default Camber plates on 2001 c5z
Alright I have searched and can't find anything. I'm trying to setup my car for the drag strip. I want the rear camber at .5 positive camber. I know about camber plates but it seems they all are made for more negative camber. Will they go positive? How do they work exactly?
mrr23 (01-31-2016)
Old 01-31-2016, 12:00 PM
Bill Curlee
Support Corvetteforum!
Bill Curlee's Avatar
Received 2,180 Likes on 1,583 Posts
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I have never set my car up for drag BUT,, your suspension had FOUR CAM adjusted points that allow for a wide range of adjustment.
I don't think you need anything to get to your desired adjustment. I could be wrong. Have you looked at it and tried to obtain the desired camber with the installed cams on the A Arms?
BC
mrr23 (01-31-2016)
Old 01-31-2016, 01:51 PM
mrr23
mrr23's Avatar
St. Jude Donor '15
the rear lower arms have a single eccentric cam bolt. you can get +0.50 camber with them. camber plates are for cars with struts, not shocks.
Old 01-31-2016, 03:05 PM
leadfoot4
leadfoot4's Avatar
Received 1,343 Likes on 1,094 Posts
mrr23 (02-01-2016)
Old 01-31-2016, 04:46 PM
blake-anderson
I have looked and didn't see a eccentric bolt for camber I will look again.
mrr23 (02-01-2016)
Old 01-31-2016, 08:03 PM
95wht6spd
95wht6spd's Avatar
You will see it, it has a big cam disc made into it, with degree markings.
mrr23 (02-01-2016)
Old 02-01-2016, 07:28 AM
mrr23
mrr23's Avatar
St. Jude Donor '15
right rear lower control arm front bolt.
Old 02-01-2016, 07:42 AM
leadfoot4
leadfoot4's Avatar
Look at the inner pivot bolts for the lower control arms.
Old 02-01-2016, 01:30 PM
blake-anderson
Ok I think I understand, so I adjust camber with the front eccentric bolt on the front of the lower control arm, and then fix my toe with the tie rod after. Correct?
Old 02-01-2016, 03:07 PM
leadfoot4
leadfoot4's Avatar
You adjust rear camber by loosening and adjusting BOTH lower a-arm bolts. In the front, you loosen both lower a-arm bolts to simultaneously adjust camber and caster. After setting camber and/or camber and caster, you adjust toe by adjusting the tie rods.....
Old 02-01-2016, 03:20 PM
blake-anderson
This would make sense if both lower control arm bolts were eccentric but only the front bolt is.
Old 02-01-2016, 04:47 PM
mrr23
mrr23's Avatar
St. Jude Donor '15
Correct
Signed - the alignment guy
Old 02-01-2016, 04:48 PM
mrr23
mrr23's Avatar
St. Jude Donor '15
The rear of the c5 only has one eccentric bolt. The rear arm bolt is not adjustable as the sway bar attaches to it.
Old 02-01-2016, 05:23 PM
blake-anderson
Thanks alignment guy!!
Old 02-01-2016, 05:40 PM
leadfoot4
leadfoot4's Avatar
It's been a while since I've been under there...........
To Camber plates on 2001 c5z
Quick Reply: Camber plates on 2001 c5z
