2002 z06 engine light
Old 04-30-2016, 08:45 PM
PHILLY JOE
PHILLY JOE
Support Corvetteforum!
PHILLY JOE's Avatar
Default 2002 z06 engine light
Will a dead battery and old battery after a charge start, give you the engine block light. Battery will not hold a charge. Joe
Old 04-30-2016, 08:49 PM
73Corvette
73Corvette's Avatar
Joe... Joe... the C5 is very picky about VOLTAGE. Do yourself a favor and get a good quality battery, or you are asking for all kinds of problems.
PHILLY JOE (04-30-2016)
Old 05-01-2016, 02:50 PM
PHILLY JOE
PHILLY JOE
PHILLY JOE's Avatar
Default C5 z06 2002 engine light
Originally Posted by 73corvette
joe... Joe... The c5 is very picky about voltage. Do yourself a favor and get a good quality battery, or you are asking for all kinds of problems.
thanks for the info needed another opinion. . A new battery this morning did the trick. No engine light. The car only has 10k on it. Thanks again joe
Old 05-01-2016, 05:49 PM
73Corvette
73Corvette's Avatar
COOL COOL... NOW if you haven't or don't know IF the Column Lock Issue has been addressed DO yourself ANOTHER favor and make sure it has or get the LMC5 module from Compliance Parts and INSTALL it...
Old 05-01-2016, 11:21 PM
PHILLY JOE
PHILLY JOE
PHILLY JOE's Avatar
Default Engine light
cool cool... Now if you haven't or don't know if the column lock issue has been addressed do yourself another favor and make sure it has or get the lmc5 module from compliance parts and install it...
the lmc5 i did replace about two years ago easy fix to that problem. Joe
To 2002 z06 engine light
Quick Reply: 2002 z06 engine light
