Help: Crank No-Start on New Motor
Recently swapped for a new LS3 engine using the LS1 oil pan etc. It started and ran for a few trials until I did some recent touch up work. Now I have a crank/no-start scenario with no DTC's.
Touch up work: Dropped rear cradle two inches to move some wires then bolted back up. Started before, won't start after... maybe a coincidence?
Diagnostic and "fixes" done so far:
Installed new crank position sensor
Installed new NGK TR6 plugs
Sprayed starting fluid in TB
Fully charged battery
No start at all, the starter spins the motor very strong. I can hear the fuel pump buzz. Without the starting fluid method working I'm left with ignition? But I just don't understand what could be wrong all of a sudden.
1/4 mile/AutoX
1/4 mile/AutoX
bty starting fluid is a bad idea !!!
The wires I moved were the rear ABS wires... I installed them on the wrong side and as a result were not pulling the e-brake cable through the center of the wheel opening and were rubbing on the wheel. Simple fix.
When I reinstalled the new motor I put new heat shielding around everything... including both wiring and headers (heat wrapped the primaries).
Today I will systematically pull and check fuses. I don't have a volt meter but sounds like I should have one by now. I will also double check the grounds but when I moved the rear-end, the tunnel plate was still attached to limit the movement.
Resolved
The ground behind the head had come just a little bit loose. Tightened the bolt and wouldn't ya know... started right up.
With it brings the conclusion of my rebuild. Tuning this week.
1/4 mile/AutoX
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
YEP,,, It wont run without COIL GROUNDS.
BC
BC
1/4 mile/AutoX
