98 O2 sensor wiring diagram
Old 01-25-2017, 02:49 AM
Pizzano
Pizzano's Avatar
Default 98 O2 sensor wiring diagram
Looking for a wire diagram or info concerning the drivers side O2 sensor that would be before the Cat for AFR hook up.
Headers and Hi flow cats are installed.
Signal wire color?
Old 01-25-2017, 05:46 AM
oelarse
Support Corvetteforum!
oelarse's Avatar
Hope this info cover it
Old 01-25-2017, 08:43 AM
Pizzano
Pizzano's Avatar
Old 01-26-2017, 12:49 PM
Bill Curlee
Bill Curlee's Avatar
Received 2,180 Likes on 1,583 Posts
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Just a quick question. Why did you need a O2 Sensor schematic??
Bill
Old 01-26-2017, 09:24 PM
Pizzano
Pizzano's Avatar
Bill
To determine which wire is the signal wire to tap into on drivers side for a narrow band AFR cobalt guage , and yes I know , Narrow band guage is useless this and that, I received it free and will install it until a wideband is purchased in the future.
Old 01-27-2017, 11:13 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I was just wondering if you were having issues with the sensors. That's all.
I have some extensive troubleshooting info that I can provide.
Old 01-27-2017, 10:18 PM
Pizzano
Pizzano's Avatar
By no means was I being harsh Bill for you asking , but everyone on the forums disses the narrow band ansd says there a waste of time and money, I understand that but it was free and im sure it serves some useful info, (not for tuning , but as far as simple knowledge).
I always appreciate your input Bill, if you could look at the schematic posted couple posts earlier, is it the purple/white wire that is the signal wire for the front (before cat) on the drivers side.
Thanks for your input Bill as always!
Old 01-27-2017, 10:42 PM
lionelhutz
lionelhutz's Avatar
There's a high signal = purple or positive sensor wire and a low signal = tan or negative sensor wire and you'd have to connect to both for it to work. The gauge is probably meant for a 1-wire O2 where the low side of the sensor is tied to the exhaust system. It's not likely the gauge will be accurate if you only tie to the high wire on a 4-wire O2 sensor.
If the gauge only has 1 sensor wire then you could try grounding the low wire to the same spot you ground the gauge. It would likely work but unhook it if the car quits running correctly.
Old 01-28-2017, 12:11 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I AGREE WITH LIONEL
The Purple & Purple/White wires are the signal wires.
The HO2S Low Reff return (circuit ground) wires TAN & TAN/WHITE wires are the signal return path for the circuit. All low voltage (millivolt) signals use discrete grounds ( Low Reff) to complete the circuit signal paths.
If you try to use a chassis ground for the return path, , it could very well cause bad readings or sensor issues due to the difference in ground potentials.
Something else to check . I find this BAD in a LOT of C5 that I come in contact with. That is the heater supply voltages and the ground circuit poor resistance for that circuit...
The sensors must have a properly operating heater circuit. If you look at the heater circuit fuse, you will see that is a Hot In ON supplied circuit. That voltage comes from the IGNITION SWITCH and that switch contact is well known to carbon up and supply poor current/voltage to that circuit..
Same goes for the circuit GROUND (G-105 thru Slice pack SP-122).
If it were me, I would read the voltage on the fuse test slots on top of the fuse and then check the resistance of the heater circuit from the O2 connector to battery ground.
Bill
Old 01-28-2017, 12:12 PM
Pizzano
Pizzano's Avatar
I AGREE WITH LIONEL
Bill
All good info
This is what the Gauge literature shows for installation as far as 3/4 wire hook ups , still as you can see that the purple wire from the guage gets tied into the O2 High signal (picture added below also),
Also am I correct that Bank 1 sensor is before or the front sensor, so according to your folks info then I would run the gauges purple wire to the Purple/white and the ground from the gauge would be tied into the Tan/white wire of the O2 sensor..so I will splice in another ground lead from the ground wire that was going to be grounded to chassis , and run a lead to the Tan/white . ( or a seperate ground lead from the gauge to the sensor and not the chassis)
Thank you Lionel and Bill, much appreciated, just trying to get the info correct since my son in law will be doing the back bending work ,lol
To 98 O2 sensor wiring diagram
Quick Reply: 98 O2 sensor wiring diagram
