Cleaning up heads
Old 10-15-2003, 12:05 PM
kromberg
kromberg's Avatar
Default Cleaning up heads
What type of cleaners can be used on a set of heads to clean them up and remove carbon build up on the valves?
Keith
Old 10-15-2003, 12:17 PM
Scissors
☠☣☢ Semper Ebrius ☢☣☠
Support Corvetteforum!
Scissors's Avatar
Cruise-In IV-V-VI-VII Veteran
St. Jude's Donor '06
Default Re: Cleaning up heads (kromberg)
Carb cleaner, I would think.
Old 10-15-2003, 12:23 PM
kromberg
kromberg's Avatar
Default Re: Cleaning up heads (Scissors)
Would that be safe on aluminum heads?
Keith
Old 10-15-2003, 01:17 PM
MattG
MattG's Avatar
Cruise-In I, II, III, IV & V Veteran
CI-I & II Auto-X Champ
Try the Decarbination spray you can buy from GM. It is the same stuff you spray into an engine when you do the decarb procedure. It is available in liquid form or in a spray can I believe.
Old 10-15-2003, 01:26 PM
kromberg
kromberg's Avatar
Default Re: Cleaning up heads (MattG)
Excellent idea Matt :) I will give it a try.
Keith
Old 10-15-2003, 05:00 PM
RoliO
RoliO's Avatar
I cleaned up a set of heads this past weekend. The carbon build up was pretty heavy. I used a brush and a can of Barrymans. The Barrymans is a FI type cleaner. I just dipped the brush in the Barrymans and then scrubbed and then hosed off the area I was working on. It worked great. :cheers:
Old 10-16-2003, 08:42 AM
kromberg
kromberg's Avatar
Default Re: Cleaning up heads (RoliO)
Where can one pick up some Barrymans?
Keith
Old 10-16-2003, 09:53 AM
RoliO
RoliO's Avatar
Any parts store (Auto Zone) will carry it. Good luck! :cheers:
Old 10-16-2003, 01:09 PM
SpinMonster
SpinMonster's Avatar
I assume you mean that they are off the car....I think that top engine cleaner from GM is heat dependant. I soaked a valve in the stuff cold for 24 hrs and nothing came off of it. Hope this saves you the few bucks that would have cost.
To Cleaning up heads
Quick Reply: Cleaning up heads
