[Z06] What did you do to your Z06 TODAY??
TBZ06 (01-13-2017)
#3602
Looks great, but what about air flow? I read that this set up on a C5 will obstruct airflow & raise engine temps, possibly cause overheating.
ArmchairArchitect (01-12-2017)
#3603
http://extremedimensions.com/97-04-C...Vortex-FL.html
The vortex lip has a channel open in the middle to keep air flow, click on link, check out the photos.
LIGHTNING (01-13-2017)
#3604
Go here for a good comparison:
https://www.corvetteforum.com/forums...d-c5r-lip.html
Now mind you some have had issues especially with lowered car, but others have reported no change in temps also.
After installation I noticed about a 10* decrease in temps, which was nice given SC summer temps, and with a new water pump/thermostat & program to kick the fans on sooner, I'm running a cool 180-190 regularly.
The following 3 users liked this post by nvusgt:
#3605
Ordered a Nitrous Outlet Winmax so I can finally go ahead and get the plate kit installed. Also tried to order a set of R888's from TireRack, but it wasn't letting me check out for some reason, guess I'll have to give them a call tomorrow and try to order over the phone.
Pretty pumped.
Pretty pumped.
#3606
Sent trans and diff off to get built and freshened up. Will get back with 4.10 gear as well. C5Z with big cam LS3 with intake, exhaust and gears should run like a raped ape!
#3607
Received 1,679 Likes
Took it to a Dyno Day in support of a fellow enthusiasts recent, sudden death... All of the proceeds went to his family. Put down 739/771
S.C. vette (01-14-2017)
#3608
With sub-zero temps and snow, I started the Z up to charge the battery and warm up all fluids. Yes, it's also on a tender. If the roads clear up this week (and it doesn't look good at this time), I may break out (off the hill) to do a track day at MRLS, then road trip to AZ for a day a Barrett Jackson.
Mark.
Mark.
#3609
Just completed wiring and insulation on new garage yesterday. Finally I have my Z inside! Drywall this weekend coming , so back out in driveway for the day.
#3610
Last few days checked off a few to-do items:
1. Installed LMC5
2. Installed CAGS-Skip
3. New hurst shifter ball
I screwed up the LMC5 install by skipping one of the first steps but Richard @ Compliance Parts got me sorted out super fast.
Really like the new shifter ball, plus it looks bad-***:
Hurst ball
1. Installed LMC5
Hurst ball
#3611
Finally had a decent day to play with the Z. Put C6 chrome Z wheels on, installed C6Z shifter, new shift boot, and did some black carbon fiber hash marks. I know most of you will say it needs lowered. It would look a little better yes, but I can't because of my driveway. I like the hash marks. Paying tribute to my 96 GS I sold to buy this.
#3612
WRTHW8 (01-30-2017)
#3613
Sold it......
#3614
toycloser (02-02-2017)
HONK 3X (02-06-2017)
#3617
No pics, but I installed the updated valve springs in my Z. I didn't want to risk a spring failure after reading some of the stories on here. It was really a simple job if you have a little mechanical ability and take your time. took me about 3 hours. I also did the Ranger method and installed a DEI Velcro heat shield on the clutch line (really close to the L/T's).
#3618
pulled drivetrain out.
Pulled the drivetain out for the second time in 6 months. lol
Installing:
Hinson polyurethane engine and diff mounts.
1/4" aluminum torque tube tunnel cover.
Rebuilding torque tube plus solid couplers.
all new exhaust gaskets.
catch can.
Speedbleeders and motul 600.
prolly some other stuff I'm forgetting. I have to say, pulling the drivetrain out when you know nothing is wrong with it is much less stressful. lol
#3619
Only had her 3 weeks now and its winter (just got a ton of snow) but installed my C6 shifter with custom boot, added my shiny again custom Jake plate between the exhaust, added some Rammat II behind the seats. Got lots more to do all winter.....
#3620
Installing:
catch can.
Xx_Black-out (02-08-2017)
