[Z06] my 01 z06 weighed in at 3,140lbs....
with me inside of it and a 1/4 tank of gas. getting ready to leave for the track and gonna see what i can muster out. its a h/c/i car with 4.10's and homemade dragpack. ready to rip!!
Definitely update us with your results. That combo of power/weight/gears/tires should lay down some impressive numbers.
Haven't dynod it. I actually ****ed something up Tonight lol rebuilt trans, rpm stage 2 diff w/ 4.10's. Popping a little bit now. Stage 3 prc ls6 heads. Custom grind fti streetsweeper cam. Fast 90/90. Ls9 manifolds. C6z shocks and rear sway. Removed front. Full interior. Removed a/c. Not much else really.
Had a best of 11.39@122. 1.51 60ft. I ran 12.17@114 with slicks/cai, then 11.97@115 with addition of skinnies and 4.10's.
Weight is the KILLER for performance.
Rotating weight is the worst.
wheels, tires, flywheel and clutch plates.
for ever 1 lb of rotating wt removed is about equal to 6.5 lbs of static wt removed. ie lighter wheels are the big ones.
~for every 100 lbs removed you may drop 1/10+ or more in the quarter
and 1 full sec on a 2.5 mile road course.
Removed:
a/c compressor and condenser
Front sway bar
The drag pack
Washer tank lol just cuz I had it out for master cyl
I think that's all.
16x8 replica c4 grand sport wheels. And 28x10 Hoosier drag
Front sway bar
The drag pack
I think that's all.
Received 2,054 Likes
I'm surprised it's not lighter w/o AC, how much do you weigh? My FRC has weighed as light as 2950 w/o me(I'm 150) that's with the same mods as you except passenger seat out, fuel on reserve and thinner windshield Good luck at the track, I expect a 10.x!
This is a topic near to my heart......I'm also surprised your not lighter than that.
I have a list of my weight mods if your interested...I'm at 2885-lbs-ish and just lost some more weight but have not weighted it yet...
Thanks.....and your car looks great, do you ever hit Tulsa Raceway ??
The car was 2900-2920. Scale was bouncing back n forth. I could replace optima with my 15lb and remove seat and be 2850 ish. 100% stock interior. Bigger rear way bar. Heavy exhaust manifolds and full exhaust ti. Full suspension minus front sway bar. Had 1/4 tank of gas. I've never been to Tulsa actually. Want to
That's good then, I figure the passenger seat and a/c are prolly a wash. You don't have headers though?
