Xm button missing from touch screen
Old 06-07-2007, 05:43 PM
JPG3
JPG3's Avatar
Default Xm button missing from touch screen
I got in by car and turn on the radio\ with NAV. No XM buttons on the touch screen anymore. I had added the sirius to repalce the XM, and it had been working finefor months Dealer says that the radio is a non XM, non satillite, even tough I have an antenna for XM. so they will not replace the radio.
Can anyone shed some light on this. Thanks
Old 06-07-2007, 05:52 PM
DarthStimpy
DarthStimpy's Avatar
check the connections on the Sirius unit.
this happened to mine. The plug wasn't seated all the way on the Sirius unit.
Old 06-07-2007, 05:53 PM
keg
keg's Avatar
I don't know if my problems are the same as yours. When I picked up my car for the first time the XM radio button did not show up on the touch screen. The dealers mechanic fixed the problem which he said was a bad terminal in the wiring harness to the XM radio module. The radio worked for one year and the same thing happened again. This time the mechanic call the GM tech center and they told him to replace the radio module with a newer one since the one in my car was an older unit and that GM had problems with these. So far everything has worked OK.
Old 06-08-2007, 02:35 PM
carjon
carjon's Avatar
Or Sirius module died.
Old 06-09-2007, 12:57 AM
dgrant3830
dgrant3830's Avatar
Wounded Warrior Escort '11
I think someone here in the forum said that if you discontinue the use of the XM Radio by not subscribing to it, the button will vanish on its own. I do not know if that button is replaced or continued if you are using Sirius.
Old 06-10-2007, 01:12 PM
JPG3
JPG3's Avatar
Default Wow
So I have to subscribe to XM to get the sirius. Unbelievable.
Old 06-10-2007, 01:22 PM
shortski
shortski's Avatar
x-nay, I've replaced the XM with the SIR-1 unit, no problems installed over a year ago. Check the Wiring harness and antenna connections.
Old 06-10-2007, 01:24 PM
'06 Quicksilver Z06
'06 Quicksilver Z06's Avatar
To Xm button missing from touch screen
Quick Reply: Xm button missing from touch screen
