C6 refinishing headlights/clearcoat
Old 01-18-2016, 04:52 PM
ULOSECLOWN
ULOSECLOWN's Avatar
Default C6 refinishing headlights/clearcoat
My 2009 headlights protective covering has deteriorated. I am trying to figure out if i should replace the lens or refinish?
I wet sanded with 800,1000,1500,3000 grit sandpaper lens are now nice and smooth protective covering now all removed.
I applied 3 light coats of Rustoleum Painters touch 2X ULTRA COVER GLOSS CLEARCOAT WITH UV PROTECTION. LENS ARE STILL HAZED AND SCRATCHES OR CRACKS STILL VISIBLE. SEE ATTACHED PICS.
ARE THESE LENS SALVAGEABLE? I was planning on waiting 2 days per Rustoleum and then buffing with rubbing compound , then polish and finally a paint sealant. WILL LENS CLEAR UP? OR DO I START FROM SCRATCH OR JUST BUY NEW LENS? FORUM HELP NEEDED....
Old 01-18-2016, 04:57 PM
J3TVETTE
J3TVETTE's Avatar
Wow that looks really bad, I think it may be time to replace to be honest.
Old 01-18-2016, 05:01 PM
VET4LES
VET4LES's Avatar
I think new lenses are in order. I haven't seen this work yet.
Old 01-18-2016, 05:29 PM
ULOSECLOWN
ULOSECLOWN's Avatar
Thanks for your reply... dealer states they can refinish lenses for $90 with a 2 yr warranty...
Old 01-18-2016, 05:41 PM
RLSebring
Supporting Vendor
Support Corvetteforum!
RLSebring's Avatar
Location: Pensacola Florida GO GATORS!!! www.rlsebring.com www.c6c7vette.com
St. Jude Donor '17
Here's my take for what it's worth. There are a few threads here where the owners did the wet sanding and clear coat. All required a lot of elbow grease. I don't recall any using rattle can clear most used a more expensive clear. I haven't personally heard of any of the results lasting more than a year. You'll have to determine what your time is worth.
AS far as the dealer 1) I think when he physically sees the Corvette he'll back away from the refinish deal. If not I believe you'll be dealing with him a lot during those 2 years. Most lens refinishing deals and kits are meant for acrylic/lexan plastic that are on most cars.
Replacing lens, more money initially but then your done for 5 or so years and you know what the instant results are.
Old 01-18-2016, 07:47 PM
joec
joec's Avatar
ummmm , nope those look toast to me.. Call R&L and get your lenses re-done..
Old 01-18-2016, 09:15 PM
Not So Fast
Not So Fast's Avatar
Listen to post #5 he knows lenses quite well, probably wind up using his talents sooner of later.
NSF
Old 01-18-2016, 10:24 PM
4SUMERZ
Race Car Tech
4SUMERZ's Avatar
Received 2,320 Likes on 1,664 Posts
NSF
RL is the man for lenses
Old 01-18-2016, 10:31 PM
11LS3A6
11LS3A6's Avatar
Not that I am shocked, but how do they get away with advertising whatever that stuff is on TV that they show doing the trick---- or have they been shut down for this very reason?
Old 01-18-2016, 10:38 PM
4SUMERZ
Race Car Tech
4SUMERZ's Avatar
Spray bug repellent on the lenses, and they will be clear for a little while as well.
It's all snake oil for sure.
Old 01-19-2016, 01:27 AM
ULOSECLOWN
ULOSECLOWN's Avatar
Thanks for the info. Aren't the lens hard to install? I believe I read I would have to bake headlights in an oven??? :crazy :
Old 01-19-2016, 07:21 AM
cvm
cvm's Avatar
After the sanding step which in my limited experience should be fine finishing at 3k, you need to buff the out w/ compound just like paint-M105/205; etc. did you buff? if not here is most of your problem. Even the Meg. Plastic-X at auto stores works well.
Old 01-19-2016, 07:38 AM
lynnt
lynnt's Avatar
Get the headlight kit from Sylvania and use their UV block clear coat that comes with the kit it should clear up the haze Then spray the Rustoleum clear coat
Old 01-19-2016, 10:56 AM
Not So Fast
Either liv2tour (Paul) or RL Sebring will answer in depth, its not so easy
NSF
Old 01-19-2016, 11:33 AM
4SUMERZ
Race Car Tech
4SUMERZ's Avatar
Either luv2tour (Paul) or RL Sebring will answer in depth, its not so easy
NSF
When you buy your lenses from Robert (RLSebring), he will send you the detailed instructions on how to do it.
I'm pretty much game for any project, so for me I dug right in with Robert's help.
Just need a regular oven, a pair of gloves and a few basic tools and a bit of patience.
I found the hardest part was removing the headlights from the fenders.
Removing the lens and installing the new was a fairly easy process.
It sounds daunting, but really not.
Good Luck
To C6 refinishing headlights/clearcoat
Quick Reply: C6 refinishing headlights/clearcoat
