Turning off DRLs permanently
Old 12-23-2004, 09:12 AM
Boozman
Boozman's Avatar
Originally Posted by TA
I guess to each his own......I just don't see what the big deal is with having DRLs. Is it really that bothersome?
Boozman is offline
Old 12-23-2004, 09:24 AM
Scissors
☠☣☢ Semper Ebrius ☢☣☠
Support Corvetteforum!
Scissors's Avatar
Cruise-In IV-V-VI-VII Veteran
St. Jude's Donor '06
Originally Posted by Jinx
Wasn't there a single fuse that governed DRLs on C5?
Is there an equivalent fuse on C6?
There was one on the C5. But removing it also resulting in the approach lights not working.
Scissors is offline
Old 12-23-2004, 09:33 AM
JFTaylor
JFTaylor's Avatar
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Default DRLs
Originally Posted by Buster1
DRLs can be temporarily turned off by turning the light ring on the stalk from auto, towards you to off. It will spring back to the auto position, but the DRLs will be off until you re-start the car.
That's what mine do. Interesting that SilverCoupe's stay off. Maybe that happens due to a wiring error at the factory caused by the camera crew passing by.
JFTaylor is offline
Old 12-23-2004, 10:45 AM
Vette_DD
Vette_DD's Avatar
Received 1,276 Likes on 935 Posts
Not quite correct. They stayed off in the 6-spd PR coupe after I twisted the dash light dimmer switch AND put the light switch in the AUTO position. For some reason, that technique does not work in the auto tranny coupe. I'll be experimenting more the next few days with the Silver auto tranny coupe.
Vette_DD is offline
Old 12-23-2004, 12:32 PM
FlyinLow
FlyinLow's Avatar
Someone look in the boxes under the hood. There might be a relay that you can pull that turns on the DRL's. That's the way I defeated them in my GTO. Just another option to look for.
FlyinLow is offline
Old 12-23-2004, 12:47 PM
LTC Z06
Get Some!
LTC Z06's Avatar
I live by "safety first".
Be safe out there, life is short.
LTC Z06 is offline
Old 12-23-2004, 03:01 PM
LS WON
LS WON's Avatar
Default No disconnecting is necessary
Just use the light switch and find the setting and you can drive without DRL's.
LS WON is offline
Old 12-23-2004, 03:32 PM
jschindler
jschindler's Avatar
On a six speed car, they go off when you put the parking brake on. Anyone checking to see how they work need to keep this in mind.
jschindler is offline
Old 12-23-2004, 06:15 PM
FLC6
FLC6's Avatar
LS won,
Did you EVEN read this thread? Geeez man.
FLC6 is offline
Old 12-23-2004, 06:20 PM
Vette_DD
Vette_DD's Avatar
per·ma·nent (pûrÆmà nÃnt), adj.
1. existing perpetually; everlasting, esp. without significant change.
2. intended to exist or function for a long, indefinite period without regard to unforeseeable conditions
Vette_DD is offline
Old 12-30-2004, 01:17 PM
Vette_DD
Vette_DD's Avatar
I'm going to give up on trying to get the DRLs to turn off permanently with the auto tranny. When I thought the "AUTO" selection on the lighting stalk was preventing the DRLs from coming on, I was just looking at the instrument panel indication. I finally found out there is no DRL indication there: that light is for the parking lamps.
However, the process I posted at the beginning of this thread did work for my manual tranny C6. I looked at the lights like I should have done with the auto.
Learned something again today.
Vette_DD is offline
Old 12-31-2004, 07:11 AM
LS WON
LS WON's Avatar
Default Some people have to learn the hard way
LS WON is offline
Old 12-31-2004, 07:17 AM
  #33
LS WON
LS WON's Avatar
Default You guys are that stupid?
Originally Posted by FLC6
LS won,
It is much more logical to shut if off (it is called a SWITCH) Did you know it is much easier to use the switch than tampering with SAFETY equipment and risking messing the whole car up blaming the car and the person/owner not taking responsibility for messing the car up (bubba)
Besides I was only offering information and saving you trouble of tearing your car up/messing it up.
This is an alternative so you don't have to shoot the messenger in this case as my intentions mean well.
Many times it isn't the product that is faulty but the IdXXts that modify and mess up the car in conclusion blaming the product giving it a bad name and the company unjustly.
LS WON is offline
Old 12-31-2004, 11:04 AM
  #34
HERK
HERK's Avatar
WHY?
HERK is offline
Old 12-31-2004, 01:16 PM
  #35
GTC
GTC's Avatar
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04-'05
Originally Posted by HERK
WHY?
For me, it is a little bit of extra insurance against speeding tickets. By the DRLs, you can see a vette coming from a long way off, and they are distinctive enough to know it is a vette. With the DRLs disabled, you have to be much closer before you know it is a vette. Some (not all) LEOs pay extra special attention to cars that can go fast.
No, I am not paranoid. They really are out to get me.
And yes, with C5's, you could pull a fuse to disable the DRLs. As Scissors mentioned, it would disable some of the approach lights when you remotely unlock your car, but it still lit up your fog lights and rear brake lights.
GTC is offline
Old 12-31-2004, 03:12 PM
  #36
jmess
jmess's Avatar
I got a ticket in our Lexus a while back and I feel the main reason was the DRLs caught the cop's attention at I was coming at him. He saw me before I saw him and got me with instant on radar. I was able to get on the brakes and get from 95 to 72 before the radar got a lock. The cop didn't have DRLs. Since my wife drives the car most of the time I haven't disabled them but having the option of turning them off would be good thing.
jmess is offline
Old 12-31-2004, 03:24 PM
  #37
Vette_DD
Vette_DD's Avatar
There's no problem turning them off. Just one flip of the wrist with the light-control stalk. But they come back on every time you start the car. Some folks would like to turn them off permanently, which is why this thread was started.
Vette_DD is offline
gsl0204 (10-14-2023)
To Turning off DRLs permanently
Old 12-31-2004, 03:35 PM
  #38
FLC6
FLC6's Avatar
LOL, some people are so funny. They are lazy and don't read the thread before they post. I also can't stand the people that HAVE to state their opinion as to WHY we would want to do such a thing as permanently turn off the DRL. We don't care! We just want to know how to turn these damn things off forever!
FLC6 is offline
Old 12-31-2004, 07:42 PM
  #39
FastMover
FastMover's Avatar
Location: Tellico Plains, Tn "Wolf" Official Corvette Guard Dog
Cruise-In II Veteran
Cruise-In III Veteran
What does it matter why, the post was how
[QUOTE=GTC]For me, it is a little bit of extra insurance against speeding tickets. By the DRLs, you can see a vette coming from a long way off, and they are distinctive enough to know it is a vette. With the DRLs disabled, you have to be much closer before you know it is a vette. Some (not all) LEOs pay extra special attention to cars that can go fast.
No, I am not paranoid. They really are out to get me. [QUOTE=GTC]
or to put another way just because you are paranoid doesn't mean they
are NOT after you
FastMover is offline
Old 12-31-2004, 09:27 PM
  #40
rwpatte
rwpatte's Avatar
Me too. No lectures please!!!!
rwpatte is offline
Quick Reply: Turning off DRLs permanently
