If you know Wiseco pistons, please step inside...
Location: Greater Detroit Metro MI, when I'm not travelling.
So, as you know, my "9.8:1" engine compression tests out as 145PSI... Theoretically the number should be 172PSI. I am wondering if the pistons that are in there are not really -11CC chambers... Does anyone know?
The number on the piston reads "6444X05"
According to their parts catalog its a -11cc dish. The only way to know for sure was to CC them. But from what your pictures show I would say its close comparing to a Arias piston with a -12cc dish. It looks very close as both have a very similar design.
No, I did not. I ran the leakdown test and it came out fine, then I ran the compression test again and it came out as 145PSI again, so I am trying to figure out how the engine can have low compression when it is not leaking any pressure...
Compression PSI
Cam duration, overlap, and phasing strongly affect (reduces) actual cranking compression pressure readings. Have you factored these into your theoretical compression PSI reading?
Barry
Barry
Is the throttle plate open during cranking and how many times do you crank the engine over on each cyclinder ?
145 PSI is pretty low. Something seems amiss to me. Have you thought about pulling one head to confirm that the correct pistons went into your engine.
Not sure if you access to a boroscope and can verify the correct pistons are in there without pulling the head.
Hope you get it figured out soon.
I had the head boroscoped, the piston I see is the one pictured here.
May pull a head later on, I'm too busy now though.
Have yor verified push rod length to see that they are the correct length ? maybe they are too short and you're not taking in enough air ?
Up to certain point that is true, use to long of a push rod and you could have some nasty problems.
If the pushrods are too short, it could explain the loss of compression.
I don't disagree with you but I've always learned to start with the basics and begin the process of elimination in diagnosing any problem.
