LS7 will Handel these stuff
Hi guys
I have c6 zo6 2012 with ARH 1.7.8 , x-pipe and exterm Corsa catback
I am welling to add a supercharge with 5 psi and spray 100 hp with plate system
My concern is :
Will the ls7 handel those stuff for daily use ???
By the way I will not spray the Nos much
Regards
Faisal
My concern is :
Regards
Faisal
The LS7 will tolerate quite a bit. What it won't tolerate, or any engine for that matter, is any form uncontrolled ignition or detonation.
Good fuel and a good tune will decide how reliable your car will be.
Seen a few hold up. But not the norm for sure. And the liners are more susceptible to cracking, but its usually caused by some other failure such as a valve or piston giving up not hp or cylinder pressure. GL!
So what you suggested for me guys as i am not willing to change bottom and daily use ?
The nos plate system with 100 hp
Or supercharged with 5 or 6 psi
I knew the cost is wide different
But I wana let the engine run in normal situation for long term ?
Also if I decide to go for supercharged
What kind of supercharged is easy for installation and not need much modefecation in Ls7 as I am staying in Saudia Arabia and few work shop know how to install the supercharge in right way ??
Thanx a lot guys
Regards
Faisal
Thanx a lot guys
Regards
Faisal
Choose one or the other, not both. Either do a 100-150 shot with heads/cam, or heads/cam/blower but I wouldn't do both.
Hi guys
My concern is :
Regards
Faisal
My concern is :
Regards
Faisal
Stock short block? can handle one or the other. Not both.
Thanx a lot guys
Regards
Faisal
Thanx a lot guys
Regards
Faisal
I can set you up with a package. I have shipped plenty of engines/parts to Saudi
Either way I would address the head issues first if you want reliable.
Thanks a lot guys for your responsed.
Regarding to the supercharge
Which kind of supercharge is the easiest one in installation in ls7 and not complicated or need less modification to install it ?
Regards
Regards
Any of them are simple. Only one I wouldn't recommend is the eforce for those numbers, otherwise ECS, AA, PC, Whipple, Maggie, etc can all do 650 .
