Punching out cats on Kooks LT Headers
I posted in the tech forum as well. I thought I may get more responses here. What is the best method since the cat is made of metal? Would an air chisel be my best bet?
Received 1,194 Likes
St. Jude Donor '15
I've seen a recommendation to use one of those wood boring drill bits before.. A long one preferably. And a pipe + hammer
Long wood bore bit. The fatter the better. Yes you have metal in there, but its not solid, its a honeycomb.
Drill multiple holes all the way through. Then use a metal rod and a hammer to knock out the rest.
I often times will heat the outside with a torch as well.
That's how I did mine and it worked, PITA though
