C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Overdrive crank dampers
Old 12-26-2015, 10:22 AM
GeneSch
GeneSch's Avatar
Do you have the part number.
Old 12-26-2015, 10:26 AM
realcanuk
realcanuk's Avatar
St. Jude Donor '13
8 rib damper P/N 917345
P/N 917107 is 7.96 diameter which is 8% over driven.
P/N 917108 is 8.23 diameter which is 12% over driven.
Old 12-26-2015, 10:28 AM
realcanuk
realcanuk's Avatar
St. Jude Donor '13
Copy pasted from the email from ATI. Keep in mind my car is an LS2. I can't say if LS3 is the same.
Old 12-26-2015, 10:40 AM
M M Alexander
M M Alexander's Avatar
Originally Posted by CI GS
I take it that yours doesn't hit the water pump pulley? Are you running the stock LS3 WP? How hard is it to get the belt on?
Fits just fine - running stock LS3 pump. I snapped a belt 2 months back and swapped it out in a Night clubs parking lot in about 15 minutes.
CI GS (12-26-2015)
Old 12-26-2015, 10:45 AM
timmyZ06
timmyZ06's Avatar
Originally Posted by realcanuk
ATI makes an 8% or 12% overdrive. Running the 8 myself.
Direct drives?
Old 12-26-2015, 11:05 AM
Detoxx03
Detoxx03's Avatar
10 rib I'm running is: 6% OD – 8.190” P/N 917094
Old 12-26-2015, 01:29 PM
CI GS
CI GS's Avatar
Received 1,110 Likes on 780 Posts
Below is a snapshot from ATIs website with the numbers for a full 8 & 10 rib pulley setups (sans blower pulley) from ATI. You have to decide whether you want the 8% or 12% outer shell as per realcanuck's post above.
This kit retails for around $1000 from Summit.
Old 12-26-2015, 03:38 PM
JetstreamGS
JetstreamGS's Avatar
What options are available for stock 6-rib setup? Not looking to upgrade at this time.
Old 12-26-2015, 04:07 PM
Unreal
Unreal's Avatar
Received 2,313 Likes on 1,793 Posts
Buy an 8 or 10 now and use it with a 6
The following 2 users liked this post by Unreal:
JetstreamGS (12-26-2015), timmyZ06 (03-25-2016)
Old 12-26-2015, 05:10 PM
old motorhead
old motorhead's Avatar
Received 1,339 Likes on 947 Posts
Powerbond seems to be the best bang for the buck, although ATI and IW are top of the line products. The best prices I've seen on these are at Colorado Speed. The second one from the bottom on the list below would be the one you need for your dry sump car. NB: It's listed as being 7.64" in diameter, but it's also shown as being 10% overdrive. We've had a discussion on another thread about this and it appears that Powerbond has an erroneous diameter measurement for this and the one right above it, which is the one I need for my A6 car, which I have verified is actually 8.25" in diameter.
I think oldmotorhead has one of these that he's about to install on his car. Hopefully he can chime in.
Merry Christmas, BTW.
Yes, the damper referenced by Samuel L. is actually 8.25". Just measured it, and it's resting comfortably on my pool table.
Old 12-26-2015, 06:39 PM
CI GS
CI GS's Avatar
When are you gonna install that thing? Next thing you'll be telling us you're using it as an ashtray!
Old 12-27-2015, 07:57 AM
old motorhead
Tooner on vacation. I "think" we're scheduled for the second week in January.
Old 12-27-2015, 09:41 AM
  #33
scottg
scottg's Avatar
No- No- No Sammy L, He his now telling us he's got so much money because he did not have to get a water heater he can now use his Italian 1" slate pool table for a workbench. Some guys have it all. Just to keep this on thread, Thank-you Rodney for rubbing it in.
Old 12-27-2015, 03:05 PM
  #34
Streetk14
Streetk14's Avatar
Everyone needs to remember the OP has a dry sump motor. So an LS7 style balancer is needed. Not many overdrive options. None in an overdrive 6 rib as far as I remember. Seems like buying an 8 rib pulley and just using a 6 rib belt is the way to do it for a dry sump car.
And I can't remember exactly, but I think the ATI version doesn't come with an AC belt option. Don't know why, but that's what I was looking into as my first choice.
Old 12-27-2015, 03:59 PM
  #35
CI GS
CI GS's Avatar
I don't think anyone makes an O/D balancer in 6-rib for the non-dry sump Y-body car either?
The powerbond part number that I referred to earlier in this thread is for the dry-sump Y-body and is the same one that Rodney must have (I assume his car is a dry-sump?). I'm pretty sure that has an A/C pulley.
Old 12-27-2015, 06:02 PM
  #36
old motorhead
You're correct on the dry sump. Also correct on that damper having an a/c drive. I'd MUCH rather be slow than uncool...
Old 12-27-2015, 06:06 PM
  #37
Streetk14
Streetk14's Avatar
Yep... I gave Rodney the part number for that Powerbond pulley. It's for a dry sump motor. I was referring to the ATI pulley not having an AC groove. They'd be my first choice if they made what I'd want. IW would be my second choice, though I really wish they came in another finish.
You might be right about there not being ANY 6 rib overdrive pulleys. Thought someone made one, but maybe not. Even so, there's just way more choices if shopping for a wet sump pulley.
To Overdrive crank dampers
Old 12-27-2015, 06:33 PM
  #38
CI GS
CI GS's Avatar
We get that, Hot Rod!
Old 12-27-2015, 06:45 PM
  #39
CI GS
CI GS's Avatar
Yep, you're right Andy. As Rodney always says, "you're always right!"
It appears from ATIs online catalog that for the LS7 (and dry sump LS3) the two OD 8-rib dampers they offer only comes in a non-A/C version, whilst the OEM diameter has the A/C pulley?
See below:
Old 12-27-2015, 06:54 PM
  #40
GeneSch
GeneSch's Avatar
This should be fine
http://www.briantooleyracing.com/ati...-c-pulley.html
Quick Reply: Overdrive crank dampers
