Dashlogic
#62
Yes, reads the same as the Boost provided. Still reading lower than expected, so I have a different issue. Can the Dashlogic read the sensors with the car off somehow? I would like to check 0 on the MAP for calibration.
#63
Did you install a 2 bar MAP? I assume you have by the fact you see 6psi, but boost isn't an absolute pressure so I guess anything is possible.
#65
Received 1,194 Likes
St. Jude Donor '15
#66
Thanks for all the work you do on the HPTuners forum too. I've learned a lot over there.
#67
St. Jude Donor '15
No problem. I have a few more DIY's I need to get posted up.
I went outside and figured out how to get dash logic to come on earlier then forgot to post it, oops.
You got it though.. the way I did it earlier was I started car, turned it off but did not put it in reverse so it didn't turn all the way off. Hit the start button (didn't push in clutch) and after maybe 5 seconds dash logic came up. Mine was dead nuts on 0.0psi with engine off.
#68
as others stated needs to not be the stock MAP sensor
Just keep in mind the DashLogic reports everything on a mild delay (maybe 1/4 second).
Here's boost in action you'll see the minor delay on the gear shifts still showing boost then shows vacuum for a short bit while back in gear.
It's subtle but it's there...pause video if you don't believe me but in real world it's there.
It didn't bother me but something to be aware all things reported by it are on small delay.
#69
0 PSI
#70
You also still have install a wideband O2 sensor to get A/F, correct?
#71
St. Jude Donor '15
Both of which should be done regardless
#72
St. Jude Donor '15
I think anyone in the FI world should have a wideband except maybe the lowest boost Edelbrock type setups
#74
Most just like the insurance, weak fuel pump, run out of meth, or any number of things will show up on the wideband and possibly save your engine. If everything is working well you don't need any gauges, but who ever trusts in everything working well?
#75
What color is the blinking light?
This is the most recent working firmware if you want to test it out also
https://www.dropbox.com/s/lgdlu7mjmo...20fix.ehx?dl=0
#76
For now they are just on Palmer Performance site. The one linked isn't fully official yet. Once it has passed all the tests, it will be posted on the site.
#77
#78
I guess the Auto's are different. I tried every combination I could think up including that suggested above, but could not read Dashlogic with the engine off. Is there a way Dashlogic? I really want to check the calibration of the MAP sensor I bought in case that is the issue.
#79
