A&A bracket belt size
Anyone knows the size for a 6 rib belt on a t-trim with a 3.47 pulley and a iw 10% overdrive crank pulley? And how much power would a 6 rib handle before belt slip becomes an issue? Just curious on does questions if anyone has any input
thank you i have went over that chart already but they dont have a 6rib serpertine belt size to use with a 8ich balancer and that pulley closes size i googled was GATES K060923HD just wanted to see if anyone else has used it in that configuration
Platinum Supporting Vendor
If it's a full length setup and not using a Flip drive or Secondary drive get a 92" 6-rib belt. Probably a K060923 Gates belt.
thanks i had added the difference from the crank balancer and added it to the belt you guys have on the chart for 6 rib just wanted some confirmation thank you
