C6 1/4 Mile Performance Challenge
#6881
category ls3 power adder
4. Year Corvette 2008
5. Type of Trans A6
6. Type of Suspension Base
7. Stock Performance options (as in optional gears with the automatic, & etc.) 2.56 Gears
8. Tires utilized et street bias 26x11.5x16
9. Modifications: honker intake, 1.75" longtunes with bullet mufflers and turn downs 3200 fti stall, ky speed spec cam, bluecat tune, 90mm plate kit 150 shot
11. As much info you may want to add about the run, launch techniques, tire air pressure & etc 16psi rears 40 psi fronts 1/4 tank of gasoline, lflashing the converter
12. Typed in the post (as some time slips get deleted & etc after being posted)
___ Name of the Track mountain park dragway in kentucky
___ Date of the pass & weather conditions 10/26/14 1980 da
___ 60'.............1.654
___ 330'...........4.547
___ 660'...........6.854
___ 660’ mph....105.857
___ 1000'..........
___ 1320'......10.445
___ 1320’ mph….134.447
had some nitrous issues but workin on that
#6882
LS3 10.31 At 130.20
Category : LS3 Internal Modifications
1. Your entire profile completed & read Instructions: Yes
2. A copy of your entire time slip posted to the thread as in post #_____:Time slip posted below
3. The complete the details of your pass using this template in your post:
4. Year Corvette: 2008
5. Type of Trans: A4
6. Type of Suspension: Z51 with JOC stage 1 sways and shocks removed front sway bar
7. Stock Performance options stock NPP exhaust, Deleted Mufflers
8. Tires utilized: Hoosier 275/40/17 on C5 fronts and GTO Spares with M&H tires
9. Modifications if any: G6X3 cam and ported stock heads, UDP, EWP, A4 with 3.42 Diff, Yank 4000 ss conv, 1 7/8" LTH with cats, Vararam cold air with filter, drag radials, Ported stock intake, NW 102 TB, Meth Injection, James Karger Tune.
10. Dyno numbers if you have them 522.3 RWHP, 494.9 ftlb torque.
11. As much info you may want to add about the run, launch techniques, tire air pressure 20 PSI, 6800 shift points, Video is 10.37 pass car spun on launch
___ Name of the Track: Texas Motorplex
___ Date of the pass & weather conditions: Sunny Clear 10/25/2014. 77 degrees. DA +1845
___ 60'............. 1.397
___ 330'........... 4.161
___ 660'........... 6.533
___ 660’ mph.... 102.46
___ 1000'......... 8.581
___ 1320'......... 10.316
___ 1320’ mph...130.20
#6883
Category : LS3 Internal Modifications 1. Your entire profile completed & read Instructions: Yes 2. A copy of your entire time slip posted to the thread as in post #_____:Time slip posted below 3. The complete the details of your pass using this template in your post: 4. Year Corvette: 2008 5. Type of Trans: A4 6. Type of Suspension: Z51 with JOC stage 1 sways and shocks removed front sway bar 7. Stock Performance options stock NPP exhaust, Deleted Mufflers 8. Tires utilized: Hoosier 275/40/17 on C5 fronts and GTO Spares with M&H tires 9. Modifications if any: G6X3 cam and ported stock heads, UDP, EWP, A4 with 3.42 Diff, Yank 4000 ss conv, 1 7/8" LTH with cats, Vararam cold air with filter, drag radials, Ported stock intake, NW 102 TB, Meth Injection, James Karger Tune. 10. Dyno numbers if you have them 522.3 RWHP, 494.9 ftlb torque. 11. As much info you may want to add about the run, launch techniques, tire air pressure 20 PSI, 6800 shift points, Video is 10.37 pass car spun on launch 12. Typed in the post (as some time slips get deleted & etc after being posted) ___ Name of the Track: Texas Motorplex ___ Date of the pass & weather conditions: Sunny Clear 10/25/2014. 77 degrees. DA +1845 ___ 60'............. 1.397 ___ 330'........... 4.161 ___ 660'........... 6.533 ___ 660 mph.... 102.46 ___ 1000'......... 8.581 ___ 1320'......... 10.316 ___ 1320 mph...130.20
#6884
Great runs BSPC608...nice to have met you though sorry I have dropped your name. Very stout and consistent C6!!!
Congrats on...the top spot!!!!
Rick
Rick
#6885
Sorry Tommy (and forum) as I didn't post the entire time slip...
Finally took my 10' M6 Grand Sport to the track. If the day goes well I will have a 1/4 time slip to share after tonight (The Texas Motorplex is open for a rare Test n Tune tonight).
1st pass dropped the clutch at 2k and eased into throttle...bogged bad.
2nd pass 3500 launch...too much, spun hard.
3rd pass was a charm and I took her home after that (very happy with the MPH):
Category : Internal Engine Mods/Grand Sport
2. A copy of your entire time slip posted to the thread as in post # _____
4. 2010 Grand Sport
5. M6
6. Stock
7. Stock
8. 345/30/19 Nitto NT05R's
9. Headers, hi flow cats, CAI, Cam, ported throttle body, 160 stat, QMS Tune, stock unopened long block
10. 472rwhp 115 degree shop ambient that day
11. 20psi rear tires, no burnout, hit it to clean the tires off, dumped the clutch at about 2500 RPM and hammered it, spun pretty hard but the 60' is decent (I think?)
___ Northstar Dragway (Sanger, TX)
___ 10/23/14 8:45pm, 74 degrees?
___ 60' 1.7582
___ 330' 4.8707
___ 1/8th mile ET 7.4608
___ 1/8th mile MPH 98.45MPH
4. 2010 Grand Sport
5. M6
6. Stock
7. Stock
___ 60' 1.7582
___ 330' 4.8707
#6887
Btw my bolt on time was never updated from post 6531#
11.112
https://www.corvetteforum.com/forums...post1583503731
#6888
hell yA!!!!
11.112
1.47 60ft? I think we need to look at my tune lol. I'm barely able to pull a 1.59.
#6890
<<<@!1!@>>>
Car always 60footed its *** off. 1.47 stock cam and 1.41 cammed.
loose as **** 3800 PAS.
Video Link: https://www.youtube.com/watch?v=eGAAXw6dC9g
#6891
hell yA!!!!
11.112
11.112
Sorry Shane
It is now updated
Tommy
#6892
Got some run's in at the private HPFreaks "DRAGula" event...and a nice time slip to show for it posted below!
4. 2010 Grand Sport
5. M6
6. Stock
7. Stock
9. Headers, hi flow cats, CAI, Cam, ported throttle body, 160 stat, QMS Tune, heads have never been off the car
11. 19psi rear tires,
___ The Texas Motorplex
___ 11/1/14 2.07pm around 60 degrees
___ 60' 1.740
___ 330' 4.897
___ 1/8th mile ET 7.493
___ 1/8th mile MPH 96.24MPH
___ 1000' 9.684
___ 1/4 mile ET 11.543
___ 1/4 mile MPH 121.55
4. 2010 Grand Sport
5. M6
6. Stock
7. Stock
___ 60' 1.740
___ 330' 4.897
___ 1000' 9.684
#6893
New PB 10.125 @ 132.24 LS3
Tommy could you please update my new time.
11. As much info you may want to add about the run, launch techniques, tire air pressure 20 PSI, 6800 shift points, Tires spun on launch
___ Date of the pass & weather conditions: Sunny Clear 11/1/2014. 48 degrees. DA -600
___ 60'............. 1.388
___ 330'........... 4.095
___ 660'........... 6.411
___ 660’ mph.... 106.74
___ 1000'......... 8.424
___ 1320'......... 10.125
___ 1320’ mph...132.24
#6894
Received 2,054 Likes
#6896
Move me up some!
Category: LS3 Bolt On
2. A copy of your entire time slip posted to the thread as in post # _____ posted below
5. Type of Trans A6
6. Type of Suspension Base w/ Z06 Shocks and Z51 Brakes & Swaybars
7. Stock Performance options (as in optional gears with the automatic, & etc.) 2.73 Gears
8. Tires utilized MT DR 275/40/17
9. Modifications: Stainless Works 1 7/8" Longtube headers, 3" X Pipe, c6z mufflers, Tune, (NO CAI, STOCK FILTER)
10. Dyno numbers if you have them 395rwhp/404rwtq
___ Name of the Track Pittsburgh Raceway Park
___ Date of the pass & weather conditions 11/2/14, 45* ~90ft DA
___ 60'.............1.8520
___ 330'...........5.0797
___ 660'...........7.6893
___ 660’ mph....94.74
___ 1000'.......... 9.9105
___ 1320'..........11.7714
___ 1320’ mph….122.28
5. Type of Trans A6
#6897
Bone Stock 2010 Grand Sport
Category: Grand Sport Stock
4. Year Corvette 2010
5. Type of Trans 6M
6. Type of Suspension Grand Sport
7. Stock Performance options stock 3:42 Gears
8. Tires utilized Stock Michelin
9. Modifications: No modifications
10. No Dyno numbers
11. As much info you may want to add about the run: 1800 RPM slow clutch release, rears 28 psi fronts fronts 44 psi, 1/4 tank of gasoline,
___ Name of the Track Beech Bend, Bowling Green, KY
___ Date of the pass & weather conditions 1/11/14, 44 degrees Clear
___ 60'.............2.146
___ 330'...........5.497
___ 660'...........8.233
___ 660’ mph....91.84
___ 1000'.......... 10.593
___ 1320'..........12.499
___ 1320’ mph….115.35
First runs driving manual in about 5 years.
5. Type of Trans 6M
10. No Dyno numbers
#6898
Category: Grand Sport Stock 1. Your entire profile completed & read Instructions: Yes 2. A copy of your entire time slip posted to the thread as in post # _____ posted below 3. The complete the details of your pass using this template in your post: 4. Year Corvette 2010 5. Type of Trans 6M 6. Type of Suspension Grand Sport 7. Stock Performance options stock 3:42 Gears 8. Tires utilized Stock Michelin 9. Modifications: No modifications 10. No Dyno numbers 11. As much info you may want to add about the run: 1800 RPM slow clutch release, rears 28 psi fronts fronts 44 psi, 1/4 tank of gasoline, 12. Typed in the post (as some time slips get deleted & etc after being posted) ___ Name of the Track Beech Bend, Bowling Green, KY ___ Date of the pass & weather conditions 1/11/14, 44 degrees Clear ___ 60'.............2.146 ___ 330'...........5.497 ___ 660'...........8.233 ___ 660 mph....91.84 ___ 1000'.......... 10.593 ___ 1320'..........12.499 ___ 1320 mph
.115.35 First runs driving manual in about 5 years.
Mark
#6899
5. Type of Trans 6M
10. No Dyno numbers
5. Type of Trans 6M
10. No Dyno numbers
#6900
Updated Time LS3 Internal Grand Sport 1/4th Mile - 2011 Grand Sport - TR6060 - Stock Suspension - Stock Performance options (as in optional gears with the automatic, & etc.) - Weld RTS Drag Pack w/ MT 315/35-17 - Modifications: Heads ported by TEA, milled .040 and touched up by Tooley, BTR Stage 4 Cam, stock LS3 Intake, Vararam CAI, 160* Thermostat, Pfadt 1 7/8" Headers with 3" Corsa Sport out the back, McCleod RXT clutch, Tick Master - Dyno numbers: None Yet - As much info you may want to add about the run, launch techniques, tire air pressure & etc. No sway bar (not sure if that even helps) front tires @ 45 psi, rears @ 18 psi. Used Lingenfelter LNC2000 for launch control @ 4900 RPM's and released clutch as smooth and quickly as possible.
___ Beech Bend Raceway
___ 11/1/14- 44* with a 20 mph headwind
___ 60'.............1.528
___ 330'...........4.419
___ 660'...........6.825
___ 660 mph....103.52
___ 1000'.........8.903
___ 1320'.........10.655
___ 1320 mph 129.16
Didn't get my fastest pass on video of course....
___ 1320 mph 129.16
