C6 1/4 Mile Performance Challenge
Old Jan 8, 2007 | 09:42 AM
  #1301
06C6FVR's Avatar
06C6FVR
[QUOTE=yell03;1558422741]06C6FVR -
Were you a little surprised your trap speeds were not higher???
It seems when you hook your trap speeds go down, but so does your et
Not surprised at all, I was on 315/35/17 drag radials, which running a shorter tire will always drop the trap speed. Im not looking for trap speed, im looking for ET!!!
Old Jan 9, 2007 | 02:39 AM
  #1302
LS1LT1's Avatar
LS1LT1
True, and the nice part about those tires (other than their strong grip ) is that shorter/lower overall diameter (25.68" versus 26.85" stock) also lowered your final drive ratio, from a 3.42 to like a 3.60+ rear gear I think.
Old Jan 9, 2007 | 11:17 PM
  #1303
Tommy D's Avatar
Tommy D
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
St. Jude donor in memory of jpee '14
Well, decided to go to HRP tonight. Ill start with Conditions
56 Deg. 50 % humidity 30.24 Barometer
By my calculator, that comes out to -435 Density altitude....Not perfect, but very nice Got there around 515 pm, to find out they open at 2pm now and close at 8, so decided I better make a bunch of runs. Car was hot lapped all night
Raceweight 3450 with me in it. Car is a 3LT 6sp Z51, only mods are Drag radials, MTI tune, and Magnaflow mufflers (weld in, not cat back)
So, please move me up on the list for the 12.041@114.01!!!! with 1.722 60'!!!
Daren
Hey Daren,
Great way to start the new year
Old Jan 12, 2007 | 08:48 PM
  #1304
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Default Posted a new best today after a few tune tweaks
Did some scanning and noticed I was a little lean, added a bit of fuel through small increments and worked my way down to a new best.
Still 2000 DA! We just can't get a break from the heat this winter. Here are the splits:
60 - 1.709
330 - 4.969
1/8 - 7.644
MPH - 92.24
1000 - 9.936
1/4 - 11.858
MPH - 117.93
Old Jan 13, 2007 | 12:47 PM
  #1305
dennis50nj's Avatar
dennis50nj
60 - 1.709
330 - 4.969
1/8 - 7.644
MPH - 92.24
1000 - 9.936
1/4 - 11.858
MPH - 117.93
great run JOE
Old Jan 13, 2007 | 02:57 PM
  #1306
seabirdak's Avatar
seabirdak
Order in the court!
Old Jan 13, 2007 | 03:38 PM
  #1307
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Originally Posted by dennis50nj
great run JOE
Thanks Dennis! I've got my sights set on you...... I would like to squeeze a couple more MPH and tenths out of it, if I can match my performance of my stolen H/C C5 without cracking a valve cover I will be really happy. But if it stays 85 degrees here all year, like it's looking like, it'll never happen!
Old Jan 13, 2007 | 04:32 PM
  #1308
dennis50nj's Avatar
dennis50nj
thats ok Joe. i hope i am still saving a little next time ill take the 29lbs of air out
Old Jan 20, 2007 | 08:57 PM
  #1309
Evilways's Avatar
Evilways
1/20/07 Rockingham Dragway
Black Z51 Headers/Cam/Tune/ stock run flats
RT: .420
60: 1.939
330:5.258
1/8 :7.900
MPH: 92.82
1000: 10.173
1/4 :12.059
MPH: 119.18
Add me in!!!!!!!
BTW: Run flats suck...
Old Jan 20, 2007 | 09:15 PM
  #1310
Cajun @ Edgyvette's Avatar
0Cajun @ Edgyvette
Former Vendor
St. Jude Donor '07-'08-'09-'10-'11-'12'-'13-'14-'15
RT: .420
60: 1.939
330:5.258
1/8 :7.900
MPH: 92.82
1000: 10.173
1/4 :12.059
MPH: 119.18
Add me in!!!!!!!
Pretty good run for cam only car. That MPH says you can get 11.7s with a 1.6x 60ft. Keep practicing. I did not know that Rockingham had a 1/4. Thought it was a 1/8 only. Well that is a good deal since I will be in Winston- Salem in November for good. Take care, good run
Cajun
Old Jan 20, 2007 | 10:46 PM
  #1311
Evilways's Avatar
Evilways
Cajun
Rockingham is a great venue...they have a good prep guy and the staff is always cool. They do a 1/8 sometimes, but 1/4 everytime I've been down. Hope to see you there sometime.
Old Jan 20, 2007 | 11:21 PM
  #1312
dennis50nj's Avatar
dennis50nj
nice run evilways that cam makes it really move on top
Old Jan 20, 2007 | 11:30 PM
  #1313
Evilways's Avatar
Evilways
Thanks...it was probally the most fun I've had the track. I talked and ran another vette too, he was a 700 HP 03 Z...ran low 11's on drs but I'm sure he had more too.
Old Jan 21, 2007 | 11:37 PM
  #1314
Fore58's Avatar
Fore58
Nice trap speed
Old Jan 22, 2007 | 02:57 AM
  #1315
LS1LT1's Avatar
LS1LT1
Originally Posted by Fore58
Nice trap speed
Old Jan 22, 2007 | 08:38 AM
  #1316
Evilways's Avatar
Evilways
Originally Posted by LS1LT1
Thanks so much, guys...I was really hoping to hit 11's, but I think the 12.0/12.1's are it on run flats. I couldn't better than a 1.9 60ft all day. You guys need to read my heads up race with a modded and dr'ed GT500 over at the "other cars" section....I have some pics to post, hopefully I can get them loaded up here soon.....
Old Jan 22, 2007 | 11:58 PM
  #1317
Tommy D's Avatar
Tommy D
RT: .420
60: 1.939
330:5.258
1/8 :7.900
MPH: 92.82
1000: 10.173
1/4 :12.059
MPH: 119.18
Add me in!!!!!!!
You are in very nice numbers Yup, run flats really suck........ even more so when it is cold up here in Jersey
To C6 1/4 Mile Performance Challenge
Old Jan 23, 2007 | 02:11 PM
  #1318
Evilways's Avatar
Evilways
I was actually really unprepared for drag racing and forgot about all I knew until the first few runs were through....I had a full tank of gas, no fuel additives,didn't increase air pressure in fronts nor lower backs and didn't dump the windshield wiper fluid. Had I thought it through, I could've saved probally 100lbs of weight and had a bit better traction.
Old Feb 2, 2007 | 11:55 AM
  #1319
ShockerRacing's Avatar
ShockerRacing
2005 C6 6spd- Base(Non Z-51)
April 22, 2006
Byron Dragway, Illinois
Only mods were 16" MT ET Streets and homemade Air Filter
R/T - .251
60' - 1.853
330 - 5.176
1/8 - 7.921
MPH - 90.06
1000 - 10.263
1/4 - 12.219
MPH - 115.14
Old Feb 2, 2007 | 11:57 AM
  #1320
yell03's Avatar
yell03
Nice run!!!
Howard
