On dyno's, what does smoothing mean?
Old 04-29-2008, 08:03 PM
cpmtigers
cpmtigers's Avatar
Default On dyno's, what does smoothing mean?
Old 04-29-2008, 09:27 PM
Craigster05
Support Corvetteforum!
Craigster05's Avatar
St. Jude Donor '07-'08-'09-'11-'12
"Smoothing" allows the chart to show more or less detail in the lines on the graph. You'll notice some dyno sheets show more little "spikes" during the run. For Ex, a Dynojet with a smoothing scale from 0 to 5, with 0 showing the most detail of what is actually happening during the pull, 5 would be a much smoother line, and therefor more "readable".
Old 04-29-2008, 09:45 PM
cpmtigers
cpmtigers's Avatar
gotcha...thanks!
Old 04-29-2008, 11:50 PM
haljensen
haljensen's Avatar
DynoJet can gain as much as 8 peak HP by using smoothing "0" compared to smoothing "5". Ask the dyno operator to print both. If it's a cold day, low elevation and high pressure ask for uncorrected smoothing "0" to see a high number.
To On dyno's, what does smoothing mean?
Quick Reply: On dyno's, what does smoothing mean?
