Ported my spare LS2 Throttle Body and stuck it on my 06 Coupe
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I ported and polished my spare LS2 Throttle Body that I had laying around and put it on my wifes 06 Coupe. I was amazed at how much material that i removed to get it to where there wasn't a HUMP in front of the throttle blade.
Put it on and fired it up! Idle SMOOTH and reved smooth. Took it for a drive and I could tell that it had more Throttle response. No bog, no lag, just more response!
Heres a couple of pictures:
Ported and polished vs STOCK!
Ported and polished TB on the engine:
Did the job on a workmate work bench with a die grinder sporting some cartridge rolls, a flapper wheel, some 240, 380, 600 and 1000 grit wet and dry, some Wenol Metal Polish compound and some Master Formula Metal Polish.
BC
BC
BC
BC
Then with the encouragement from a few others DIY'ers I pulled the intake manifold and sent it to Spinmonster for a porting job. I got a lot of satisfaction from those simple mods..
