Russell Fuel Line Adapters
Is the fuel line connection for the Ls1 the same as the one for LT1's? I want to tap the fuel rail with this connector and turn it into a -6AN fitting.
http://www.jegs.com/i/Russell/799/64...0002/-1?CT=999
Spin I think you need the -6an to 3/8 clip for it to it our cars.
http://www.jegs.com/i/JEGS/555/10310...ductId=1287062
Some of the LT stuff is 3/16 clip.
Spin the old C4s with the LT1/LT4 engines used the very same push lock type connector as our LS cars. The only difference is that they also had a 5/16 return line, the main fuel line is also a 3/8 line just like the LS engine equipped cars.
Former Vendor
Rob.
Swagelock is TOP NOTCH = does Earls have the same problem. I do realize Swagelock and Earls are not in the same ball park.
+1 for swagelock.
My fast unit failed, good thing the motor was cold or my JSB would have been charcoal grey
Here is what I did/used....
http://forums.corvetteforum.com/c6-z...uel-rails.html
